Can I install a home subwoofer with 120 volt power
Can I install a home subwoofer with 120 volt power in a car?
Chris Frost
  • 985 Answers
Bad idea.
Buy a car sub and do the job right. Home subs aren't designed for the temperature and humidity variations in a car.
Posted on Sep 10, 2014
1 Related Answer
Anonymous
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
How to change the indicated voltage which is indicated volt adjustment
Where the power cord plugs into the unit look for a red slide switch. One side will say 220 and the other will say 120. Use a finger nail to change the switch to match your local power voltage.
Sep 21, 2015 | Panasonic 330 Watts 5.1 Channel DVD Home...
Trying to driveRHEEM RAMB-036JAZ using a Honda eu2000 generator. How to hook this up?
You have to very careful powering up home appliances on portable generators due to back feed problems to incoming lines. I would recommend getting an experienced electrician to show and explain the problems with what you are considering. Many linemen have been shocked due to backfeed. The real way to perform this is to get the controller that is put on home generating systems such as generac type systems. These automatically isolate line supply from backup power from home generators, thereby eliminating shock hazards to linemen.
If prolonged shortage, you could disconnect the wires into the furnace and install an extension cord from the furnace to the 120 volt plug on the generator. Most fans are powered on gas furnace on 120 volt. Make sure your voltage needed on your furnace before attempting emergency power up. I have seen some furnaces power by 240 volt fan motors. If it is 240 volt then use the 240 plug wired correctly. PS when you get an electrician to help you with the wiring, check out the requirement to provide grounding, to lessen your shock hazard.
Hope this helps.
Dec 19, 2014 | Heating & Cooling
Explanation of fuses on 2014 Franklin by Rushmore
Contact your local service center directly or online here:
May 03, 2014 | Crossroads 2014 Rushmore Franklin
Need arc fault breakers for a 127 volt system
If your question is in regards to a standard home panel system with a 120/240 feed the single pole arc fault breaker are rated for that installation. The 120 voltage is nominal and covers a range, usually +- 5%. So your 127 is within range for the 120 volt breaker.
Mar 05, 2014 | Electrical Supplies
Someone cut the power cord on my subwoofer RCA model rt2760 can i replace it with a standard plug?
if its a standard 120/ 240 volt cord with three cores live /nuetral/ earth yes
Aug 02, 2011 | RCA RT2760 System
I have philips hts8100 from usa , can I plug it in 220 volts or 110 volts
The Philips HTS8100 is designed to use 120 Volts AC. You could use a 220 Volt AC to 120 Volt AC Step Down transformer to power this using a 220 Volt outlet. Here is what you will need:
http://www.pcrepairshop.org/all-493964-B001TPZ294-Automatic_Transformer_Adapter_500W_110v_220v_220v_110v.html
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 11, 2011 | Philips HTS8100 Theater System
Is this the only way to run this is in a car can I put in a home.
I have mine running in my room with just a small 12v - 8amp battery (dies quickly) but if you get a power converter for 120/220v - 12v with at least 12-15amps you could run in your home easily
Nov 28, 2010 | Kenwood KSC-WA100 Car Subwoofer
Dec 26, 2009 | KLH ASW10-120 Subwoofer
44 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
