Question about Bunn Ultra-2 HP High Performance Slushy / Granita Frozen Drink Machine with 2 Hoppers - Black & Stainless Steel 120V 34000.0081
<!-- from fixya rte -->Get maintenance and shaft seal off diplay - Bunn Ultra-2 HP High Performance Slushy / Granita Frozen Drink Machine with 2 Hoppers - Black & Stainless Steel 120V 34000.0081
jasbo
  • Bunn Master
  • 2,239 Answers
Hold down the word "gourmet" near the display for 5 seconds and release when the words change. it is a hidden button to get you into the menu. press and release until you get to the "pm" question then press "ice" for yes. keep hitting gourmet until it goes through the menu and the machine restarts. this will appear every 6 months to make sure you check your seals for leaks. if you have product flowing out of the bottom or side vents of the machine, replace the seal between the auger and the drum
Posted on Jan 28, 2015
What does shaft maintenace due mean
It means your machine needs to have seals and bushings replaced. This maintenance should be performed twice per year to keep your Bunn Ultra 2 in working order. This is something you will need to call a technician in to do.
Feb 20, 2015 | Bunn Margarita Machine Ultra 2 Slush...
How do i fix a front differential leak on a 2009 jeep grand cherokee srt8
Sounds like the seal around the drive shaft yolk or the differential cover plate seal is bad depends on the leak you have...try somestop leak from auto parts store...7.99-10.00
Jan 03, 2015 | Vehicle Parts & Accessories
How to change the output shaft seal in 96 honda accord
Remove c/v shaft after you get the axle nut off pry drive shaft out of trans axle . ( I assume this is where the leak is) use a small part bar to pry out old seal. Tap into the transaxle the new seal with a small hammer . go slow be careful not to bend the seal. Lube inner lip of seal with vasaline or grease reinstall CV shaft . check fluid level in transaxle . use a repair Manuel to locate the place you have to fill the transaxle and fluid type
Oct 16, 2014 | Vehicle Parts & Accessories
How to fix a shaft seal on a bunn slushee machine
the shaft seal is the cup shaped seal between the auger and the shaft. it needs replacing on occasion. the message will come up every 6 months to make sure you check it. to clear the message- the "ultra", "gourmet" and "ice" word under the display are buttons. hold down "gourmet" for a few seconds to get into the menu then release. press "gourmet" until you get to "maintenance done" and select yes. press "gourmet" again until you get to "6 month" and select no. press gourmet until you get out of the menu and you're all set!
Dec 27, 2013 | Bunn Margarita Machine Ultra 2 Slush...
How is the prop shafts removed for maintenance?
There is no way to safely remove shafts, it's not designed to be maintenanced, it's a toy, not a top quality boat.
Sep 01, 2012 | SYMA Toys industrial 30" RC SYMA Century...
Black grease is dripping out
Front seal is leaking product through cooling drum down shaft out back by auger motor.Product builds up in base of machine and leaks out bottom.Will need a p.m. kit usually required every 6 months.
Jan 24, 2011 | Bunn Margarita Machine Ultra 2 Slush...
How often does drive shaft need servicing
There is no maintenance requirement for the drive shaft. The U joints on the drive shaft are sealed and cannot be greased. You can change the oil in the final drive and lube the spline at the final drive but that is all.
Sep 19, 2010 | 2008 BMW K 1200 S
We were having trouble with one side not freezing so we replaced the shaft seals and replaced a board on the side that wasn't freezing. It now is saying Maintenance due Shaft Seal. is there still a problem...
You need to go through the menu and tell the machine that the maintenance is done, hold down the middle button to get to the menu, then follow on screen prompts and navigate to shaft seal maintenance.
Sep 07, 2010 | Bunn Margarita Machine Ultra 2 Slush...
Yamaha Venture Motorcycle drive shaft oil seal part #
Part numbers 9,15,22, and 33 are all oil seals on that microfiche,are those the ones you found? If you can remove the seal often the part number is stamped on it somewhere, or you can take the seal to a bearing place and they can usually get a comparable one.
Mar 17, 2009 | 2000 Yamaha Royal Star Venture
Bunn Ultra-2 HP High Performance Slushy / Granita Frozen Drink Machine with 2 Hoppers - Black & Stainless Steel 120V 34000.0081 Logo
1,215 people viewed this question
Top Bunn Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Bunn Cooking Expert? Answer questions, earn points and help others
