A serial number for ANY series of a manufactured item identifies each individual item. A serial number can be just numbers or a combination of numbers and letters. Each serial number is unique.
From: https://en.wikipedia.org/wiki/Serial_code (Quote) Serial numbers identify otherwise identical individual units with many, obvious uses. Serial numbers are a deterrent against theft and counterfeit products, as they can be recorded, and stolen or otherwise irregular goods can be identified. (End quote)
Therefore, the serial number on a Mini RAE identifies that particular hand held volatile organic compound monitor.
Are you needing the engine family number, the engine serial number, or the engine size? There should be an emissions label under the hood that identifies the engine size and probably will also identify the engine family number. Finding the engine serial number will be a bit more difficult though.
Mercury's can't be identified by serial number. Please give the model number ( horsepower ) and length ( S L XL ). So it will be possible to identify your motor and give an approximative weight.
AND, no balance in your neighbourhood??
Please look at ll links:
The best way to identify a tractor is by the serial number. Serial numbers on the 9N-2N and 8N tractors are located on the left side of the engine block, just below the head and behind the oil filter. IDENTIFICATIONhttp://www.just8ns.com/Identifying-Your-Ford-Tractor.html
The NEC serial number is located on the Device Rating Label (DRL) and is clearly marked. The DRL label has the UL, FCC and NEC in bold type face and is located directly below the CAUTION sticker on the bottom side of the unit.
