JBL CREATURE II Computer Speakers Logo
Question about JBL CREATURE II Computer Speakers
How many input voltage do i need for my jbl creature ii.is it ac or dc?
rohana mallawa
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
JBL Creature needs a 18V, 3.5 Amp, AC power supply. JBL original power supply model is TA66180350-B2 made in China. In put power is 220-240V, 50 Hz-0.5 Amps. The AC supply is made to a dual rail supply inside the creature using a diode bridge.
Posted on Aug 26, 2017
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Posted on Dec 22, 2007
Anonymous
SOURCE: JBL Creature 2 Blowing Fuse
I think you made a mistake with your fuse.
With my JBL i can see 9,5A 41FU.
Posted on Sep 08, 2008
Anonymous
  • 7 Answers
SOURCE: JBL Media 100 Speaker power?
Buy a power adapter from radio shack or similar place. You need a 1000mA 12 volt dapter. Just make sure it is rated @ or above 1000mA to avoid the adapter heating up and possibly burning. The whole setup is rated @ 850mA wich 1A(1000mA) should handle with enough head room. But it might run you about $15-20. I would just buy a cheap radio with rca inputs/aux input and use that. I got one from Walmart for around $40 and it plays CD's & AM/FM.
Posted on Jun 09, 2009
Anonymous
SOURCE: I am trying to repair my JBL Creature II system.
I have the exact same problem, email me if you got your's fixed and how it was. I'm also looking for a solution, that I don't have to pay some random fee on this site for.
Posted on Nov 08, 2009
Anonymous
  • 15 Answers
SOURCE: Diaphragm problem
Yes it can be replaced and your system will be as good as new afterwards.
To get an idea of the work involved: http://www.audiofriends.nl/pdf/refoaming.pdf
There are several companies selling these so called surrounds. There are foam and rubber surrounds. Stick to the same material as you may otherwise significantly alter your system's sound. Just google "speaker repair" or "speaker surrounds" and you will find several. You can ask them to repair your speakers (which may be fairly expensive) or you can order the surrounds and glue (you can not just use any glue) and do it yourself.
I have done such repairs a few times myself and it is absolutely not difficult.
Good luck.
Posted on Nov 09, 2009
Can JBL Creature 2 speakers work on a Samsung smart tv
Do you happen to have the model of the TV? My Samsung only has two digital optical outputs. If your'e plugging in JBLs, you may only have an analogue input which won't work.
1helpful
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
1helpful
I am trying to repair my JBL Creature II system. The right channel has very low volume, and it's not the speaker. The right input signal is getting attenuated somewhere, but without a schematic it's...
Power supply
e
Went to radio shack and they had an adaptor
1helpful
Power Cord for Creature II
I looked and the only thing I could come up with is to e-mail JBL and order a new one. Radio shack, Best Buy, or Futurehsop might be able to help but you have to call them with the model number or go to the store and check it out. Here's the link to JBL if you want to order a new one.
http://www.harmanaudio.com/search_browse/partlist.asp?BrandId=JBL&MarketId=HOM&Parts=CREATUREIIBLK/230
Sorry, wish I had a better answer but there isn't much out there for this.
Jbl wiring diagram
OK
2answers
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Jbl creature II
go to the maker website and try they're support techs
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
