I heard that President Obama Canceled the National day of prayer because it offended people. Is this true?
SOURCE: I have a Casio CPW-310-1VDS
Guys, I just realised that there is a mark called AC on the back of the module next to a gold small circle pad. Once you change the battery, you need to connect a wire or paperclip or something similar between the back or positive of the battery and the pad, it should then come alive. Good luck
SOURCE: i got a president day date rolex, sometime the
Reset the time, day and date manually from scratch. Check for another 24 hours. If the problem persists that means there is interference between day and date wheels and in this case you will need watchmakers help, as to correct such a fault the watch needs to be disassembled almost completely.
