GNC On-The-Go Blender - Black Logo
G
Gary J Munoz Posted on Sep 08, 2014
Can I get a new gasket for a GNC on the go blender
Need plastic washer mounts on blade cutter
nvryder
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 04, 2019
nvryder
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3484
Points
5
Yes, you can order the replacement rubber gasket seal ring from nutri Bullet 600w or 900w which is the same size on ebay for $1.00.
GNC Live Well Blender BL3340. I need help finding the O-ring for it please?
Question edited for clarity.
It appears to be an eBay special. you may be able to buy using the diameter. Shops that sell fasteners sell O-rings, but this is likely wider, so more a gasket.
https://www.google.com/search?q=GNC+Live+Well+Blender+BL3340+replacement+O-ring
https://www.google.com/search?q=GNC+Live+Well+Blender+BL3340+replacement+gasket
Dec 11, 2023 • Blenders
2answers
I need a replacement seal for a GNC On- The-Go Blender Model HL 2574
I found a replacement gasket that work for the GNC on the go Shaker HL-2574 if anyone need some just send me a msg yaz109 hotmail dot com
Jan 18, 2017 • Blenders
GNC On the Go Blender
these have a fusible link in line with motor normally
you will need a multi meter
Can't seem to find proper gasket and blade assembly to fit Ham Beach Blender #50100 Type B-12. Any suggestions?
Possibly the gasket while it lasts on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e
Possibly the new wave action blade cutter while it lasts on cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e. For unused replacements, try typing in your model number at HB's parts site, located by clicking here . Abtecparts.com may also have traditional blades at http://www.abtecparts.com/commerce/search/products/?product_id=02AXHBha010&merchant_id=1933. Besides matching description, I would match the pictures of what you are going for against what you've got--unless you are trying something new--as much as possible. Good luck!
Need a gasket for gnc on the go live well blender model # -HL-2574
Did you get any answers? I need a gasket for my HL-2571, Made by Home Life solutions. I've written them and have not heard back.
http://www.homelifesolutionsinc.com/contact/
1helpful
2answers
Need a gasket model-hl-2574
call 1-800-645-3867. M-F. 8a-5p (est)
2helpful
2answers
New gasket installed but jar still leaks...Does gasket go between jar and cutter or between cutter and screw base?
The gasket goes between the plate to which the cutter is mounted and the base of the jar. i.e., atop the cutter and contacting the base of the jar.
Charlie
Cutter blade
UK supplier is Nesbitts
http://www.nisbets.co.uk/
2answers
Blade doesn't spin freely
Here's the parts order form from Waring:
http://www.waringproducts.com/ret/parts/
Once you receive the parts, unscrew the collar from the bottom of the jar, and the old gasket and blade assembly will pop out - sometimes you have to peel the gasket apart from blender jar, but not always.
-Tha Mp3 Doctor
11helpful
5answers
Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 • Blenders
Top GNC Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a GNC Blender Expert? Answer questions, earn points and help others
