Toshiba TV
More information as your reference
Amazon com MALLCROWN VGA cable
Is there a HMDI output on your Laptop or a VGA output. Some TV's have a DSUB input source that allows VGA depends on your laptop it could be HDMI if so TV should have an extraz HDMI input on the back and you change the source input on the TV to the HDMI 2 or HDMI 3 source depending on where you plugged in the P.C. . If HDMI you need to buy a HDMI cable.
SOURCE: How do I connect my Laptop computer to my LCD TV?
Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for
you to connect it that way. DVI/HDMI is a digital signal and if it's a
digital-based display tech TV, then you're better off using that. Also
if the TV does resolution above 1360x768 (i.e. if it does 1080p) you
can get higher resolution by going via DVI/HDMI...
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
SOURCE: how can i connect my toshiba laptop to toshiba tv with vga to rca
Go to Toshiba site or send email to UK office help.
Requesting the info.
Or type in toshiba to google and surk for the info, it is there.
SOURCE: how do you connect a toshiba laptop to a hd tv
Most new TV's have a port that looks the same as he moniter connection.
