Connection to Del 4600 desktop computer. The computer set-up wizard is not compatible with the installation instructions. In particular there is no panel to 'view available wireless networks'. I hope I've given the correct router ID---it's identified as a talktalk BE87A0 and not much else.
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
SOURCE: Cannot connect wirelessly, but can through my network cable
After a few tries and re starts it may connect itself, but if not go to Start>Run, then type 'ipconfig /flushdns'. Try connecting again, but ensure your wireless card is set to obtain IP address automatically and you have enabled wireless connection and DHCP in your routers menu. Hope this helps
SOURCE: unable to access the set-up wizard to install my wireless router.
just reset the router... do you know how?
there is a small hidden button on it that you must press and hold for some minutes firs with the router powered and then with the router not connected to power line... Try this at leas 2 times with and 2 time without power, then try accessing the router as if it were new... with the default pass that comes in the manual...
SOURCE: Internet connection lost when wireless printer added to network
for reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
SOURCE: DI-524 wireless router
OK! There we go. I got the new firmware version (V2.07)in the site WWW.dlinkla.com, compatible with my router (DI 524).In the advanced management of the router, I uploaded the new version previously dowloaded in a file,from the site.Them I got the device working good.
I hope it be usefull for someone.
SOURCE: Connecting DLink thru Comcast Cable Modem and Vonage box
i have comcast wifi and i cannot set up vp eye to eye. i try to make phone call and get message says the phone number i call is unregistered. pls help me! thanks. my email is [email protected]
