Tv was given to me but it is not set up for hd it has the original remote it will hook to cable but i have direct dish tv
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
SOURCE: RCA Guideplus Gemstar TV
one of the button switch is still working or stock up, you need to replace all the switch to besure.
SOURCE: Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
SOURCE: can't get the tv set to video input mode
You may be able to press the channel down button, past channel 1 to the av inputs.
It works on some tvs, but not all.
SOURCE: My DVD player is hooked up to my RCA truflat but i
There should be a button on the front of the TV that says TV/VIDEO or INPUT. Turn on the DVD player and put a DVD in it and press play. Press the TV/VIDEO button until the picture is present.
Good Luck....
