Question about KitchenAid Ovens
<!-- from fixya rte -->How to replace kebs277 door spring? - KitchenAid Ovens
Need Specs and sizes for a 1989 KitchenAid Superba 27 - KBS277
Are you sure of the model number? I see several KitchenAid ovens with the model number KEBS277: http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 . The single oven version is 28³??" (73.0 cm) H x 26³??" (67.9 cm) W x 23" (58.4 cm) D.
I hope this helps.
Sep 03, 2016 | KitchenAid Ovens
Microwave door will not latch closed
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
Jun 30, 2010 | Neff B4540 Stainless Steel Electric Single...
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Oven door locked, can't get plastic cover of control panel off
you have to first remove the side trim there should be some screws in the side usaly 2 but sometimes 4 ---you could have replaced just the fuse for less than 20 dollers
Aug 09, 2009 | KitchenAid Architect® KEBS277S Electric...
Kitchenaid Microwave torsion spring replacement
I just replaced torsion spring 4452396 on my microwave. We heard a "pop" and then the door got heavy. here are a couple things I learned...THE HARD WAY!
We had the stainless steel front to the door and needed spring 4452396, not 4451008. The stainless steel door is heavier so therefore a stiffer spring. I'm not sure i could justify the 4x cost in the part...but that's just the way it is. It's a bit of a pain to repair the thing..so it's worth it to get the correct spring. You don't wan to be doing this every couple of of months!
You have to remove the front panel of the door to access the springs. there are 2 of them...they cross each other in an "x" pattern on the lower part of the door. We had to pull the unit out a bit to get the spring in the hole for correct position. No need to remove the door etc. If you need help with this...email me.
My mistake was when I was trying to figure out how to gain access to the springs I assumed you did from the inside of the door. I removed the two black things you see on the lower right/left of the door (screw on the bottom of them) then proceeded to remove the two recessed screws on the inside top corners of the door. Well next thing i know.....CRASH! the whole front of the door fell off and shattered! Come to find out those screws and brackets on the bottom hold the face of the door on. The glass is intergrated into the color panel of the door..so it's one piece! 150.00 later and a new piece of glass/panel i learned a hard lesson.
Let me know if you need help...it's fairly easy to do now that I look back on it. dave [email protected]
May 14, 2008 | KitchenAid Architect Series KEMC308KSS...
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
Cleaning cycle failure
Please call KitchenAid/Whirlpool directly and ask to speak to the 'executive management team'
I had this fault for the second time and this time I spoke to the Exec Management team who said they were unaware of this as a common fault. My stove was ‘fixed’ free of charge – the fuse was replaced, again.
Please everyone who has had or is having this problem call again – this problem needs to be fixed, replacing the fuse each time or not using the self clean function is NOT a fix.
Mar 29, 2008 | KitchenAid Architect® KEBS277S Electric...
Ovens Logo
67 people viewed this question
Top KitchenAid Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
