Mountainbike film
Here is the soundtrack listing on the films website.
Arrival Secondbase Film Presents Freeride Mountain Bike Film
SOURCE: film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
SOURCE: Minolta X370 film loading problem.
First make sure your batteries are OK , camera will not work without two 1.5 v batteries. If your camera still doesnt work this is probably because the shutter is cocked but you cannot release the shutter and that is why you cannot advance the transport mechanism. The shutter release mechanism needs repairing first. SREMEDY : take bottom cover off ( 4 screws ) and locate 220 mf 6v capacitor ( it is the only one in this part of the camera , cant miss it ). Replace the capacitor while you keep an eye on the polarity ( indicated on the casing of the capacitor ) and you camera should work fine ( dont forget camera needs two 1.5v batteries to work ! )
SOURCE: Isn't recognizing there is film
I will offer a solution under the assumption, that you are not familiar with this camera. Please ensure the film is loaded correctly extending the film all the way across to the orange line located on the right side near the winding post. This ensures the film is positioned correctly and will feed onto the post. Also the film advancer may need to activated by releasing the shutter. Hope it helps. Good Luck!
SOURCE: film advance lever.
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
SOURCE: Nikon FE film winder jammed.
Is it the viewfinder or the film advance lever? If the viewfinder is not showing any image and the shutter is not getting released, then it could be a problem with the mirror box.To confirm, remove the lens and see if it gets released. To align the lens, you have to take it to the nearest service center (or repair shop).
