SOURCE: 86 isuzu clutch- master cylinder ran dry
Did you bleed the system? There is probably a bleeder on the slave cylinder and you may need to jemmy the selector fork/ Also look fro a damper valve between the master and slave cylinder... it will need bleeding too.
SOURCE: on my 1987 ford thunderbird turbo coupe 5 speed it
Are you having to add fluid? If yes, look for the leak. If no, It's the clutch master cylinder.
SOURCE: Hyd. Slave cylinder WITHOUT bleeder
you have to replace the master and slave. if there is no bleeder, you might get lucky bench bleeding it, but the whole assy, comes from dealer pre-bled. The system is sealed and even to do a clutch or trans, you shouldnt have to take it apart. DO NOT PUSH CLUTCH WITHOUT ALL PARTS HOOKED UP! youll break it.
SOURCE: 2002 Hyundai Accent won't go into gear.
Probably the arm that holds the rtelease bearing in the bell housing has slipped out of place. Get someone to depress the clutch while you check the arm is not loose. If the cylinders are working then its most likely the arm is disconected. If you are lucky you may get it put back in place by looking through the inspection hole but most likely you will have to seperate the engine and gearbox. Sorry I havent better news for you.
