Question about Toshiba Tecra 8100 Notebook
Stopped working When I turn on the power two green lights come on and in two seconds one goes off and then all I hear is the hard drive and the fan running no screen
Posted by pockety on
arben pllana
  • 1,006 Answers
I think u need to change ur hdd if ur hdd making GRRRRRRRR...If not so the problem is VGA!
Try in external monitor...If ur pc is ok in external monitor so problem is MONITOR and if still wont work in external monitor soo ur vga or motherboard have failed
Posted on Nov 09, 2007
Flashing green lightbulb
Do you hear the fans running? Do you hear the hard drive spinning? Did anything ever appear on the monitor?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 09, 2012 | Acer Veriton Computers & Internet
I have a new violation 9053 and first time to charge the green light blinks for about 10 seconds and then goes off and thje battery is now dead it seems, no lights, no power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 01, 2012 | Computers & Internet
All lights are green except the third light is red.
Mar 31, 2012 | Computers & Internet
Hi i have an r630 desktop and it did work but now i have no power to motherboard no fans cpu but i do have power to the hard drives and rom replaced power supply same problem
Maybe your motherboard is toast.
Mar 30, 2012 | Computers & Internet
When i turn on, the green light comes on then goes out,why
Mar 28, 2012 | Computers & Internet
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Pc turning off
Be more specific. Turning off when? What happens when you try to turn it on? When you have the power cord plugged in do you see any lights? When you press the power button do you hear the fan running, hear the hard drive running, see anything on the lcd screen, hear the cd drive Click once, see the light on the cd drive drawer turn on for a second or two when it clicks, hear any beeps or blinking lights?
Mar 21, 2012 | IBM Lenovo ThinkPad X40 Notebook
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
Dell 8200 green power lite comes on green hard drive lite off
Check your fans o see if they are running and if the PC isn't getting too hot because that will cause it to stop and not boot up.
Dec 29, 2009 | Dell Dimension 8200 PC Desktop
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Toshiba Tecra 8100 Notebook Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
