Question about Siemens Washing Machines
<!-- from fixya rte -->How many db does the siwamat 6120 have? - Siemens Washing Machines
Anonymous
Did you ever read a manual
device in the eu or east need to have the rating as a label
so look up the manual you either have one and cant be bothered
or just cant be bothered to look it up
how many DB between 90 and 120DB max in europe as a device that outputs noise
and more you need a special license for
Posted on Apr 28, 2015
Siwamat xli1240
Unplug it for a minute, that should reset it, if that does not work, then you need to get a meter to check the heating coil and also the water valves to see if they are ok.
Nov 11, 2013 | Washing Machines
Siwamat 2450
i am mohamad fram iran
i have a washing machine model SIWAMAT 2450
Apr 24, 2013 | Washing Machines
Buka code nokia 6120
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Jul 26, 2012 | Nokia 6120 classic Cellular Phone
6120 clasic light problum
6120 light problam
Dec 19, 2011 | Nokia 6120
Siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
Nov 22, 2011 | Siemens WDi1640 Front Load Washer / Dryer
Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Jul 17, 2009 | Siemens Washing Machines
Nokia6120ccellphone unlocking
In order to unlock your Nokia 6120 mobile follow the instructions given below & unlock your mobile by getting unlock code in this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/ .
Warning : Do not enter any wrong unlock codes on your Nokia 6120 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 6120 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6120 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6120.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6120 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6120 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6120
Jan 11, 2009 | Cell Phones
SIWAMAT 6102 (GB) Code 3 Flashing. What does this error mean
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
Sep 07, 2008 | Siemens Washing Machines
Washing Machines Logo
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Mike
Dan Webster
Dan Webster
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
