The spring fell off the ice chute door
SOURCE: Ice Dispenser lever broken
There are tiny clips but you wont see them you need a small screwdriver to lever under the bottom of the cover. Once you get one clip off you will see how the rest come off.
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
once you have the screws out , the pannel can be slid down toward the empty screw holes to gain access.
