I can not get my dvd/vcr recorder to operate. I have tried un plugging it, holding power down, etc. Everything listed in manual, but have had no luck. Display shows ''F60'' and locks up unit. Can anyone tell me any solution to this. Is this an expensive problem to fix? Any help would appreciated.
SOURCE: Panasonic DMR-ES46V shows F60 Error
F60 is a general error code usually related to a failure on the video processing board. If you have access to spare/replacement parts, this is an easy error to correct by simply replacing the board. You can recognize this board as the small board with the onboard HDMI port in the DMR-EZ47V model, and has the mini cables connecting to it. It floats above the rest of the boards in the middle back of the machine.
SOURCE: F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
SOURCE: F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
