Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
<!-- from fixya rte -->How to repair sony wega blurry screen - Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
1 Related Answer
ABRsvcs
  • 4234 Answers
SOURCE: I have a 2001 sony wega 36 inches and the channels
If you are comfortable with working inside the set where there are potentially dangerous high voltages present, you can probably fix this easily. Open up the back and remove it. Plug the set back in and turn it on. In the lower right hand side will be the flyback transformer (large red wire coming out of the top and going to the side of the picture tube). DO NOT TOUCH IT!!! On the back of the flyback should be 2 "knobs". One will be marked screen and the other focus. Carefully adjust the focus until the picture is clear. When you do this, go beyond the clear point and work the control back and forth a few times before settling in to the focused spot.
That should resolve the problem.
Dan
Posted on Apr 07, 2009
Blurry & Fuzzy Picture Sony Trinitron
Check the filter capacitor to the supply to video output card. You can locate this capacitor at the CRT base card to your Sony Trinitron. Replace this electrolytic capacitor.
Sep 28, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-40XBR700 40" CRT WEGA
I too would like to know the solution to this question...we are having the identical problem and Sony doesn't seem to know how to fix it. Although, the picture from the DVD player is perfect, the pictures for cable & video games are terrible. Very frustrating!
Aug 24, 2011 | Sony KV-40XBR700 40" TV
I have a sony trinitron 36in tv, the screen works fine, colours are all great, no flickering or random shapes at all, its just a little blurry around edges, especially small text, its very blurry and...
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Mar 13, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
What is the approximate cost to repair a Sony Wega Optical Block failure 55 inch
The parts and labors about $600 to 700 dollars any big screen tvs authorize tvs repair shop.Any big screen tvs shops can do this repair,so shop around will get a good deal.
Jul 02, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 10 yr old Sony tv that is blurry
check ur cable conections and see if thay are loose
May 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
THE PICTURES ARE BLURRY AND DISTORTED
Camera symptoms shows bad CCD Imager in camera and this part needs to be replaced.
Sony has announced free of cost repair scheme for such problem in DSC-T1 models. Please click Sony Support for details.
Thank you.
Aug 21, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Double Images
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 02, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Blurry picture screen
Please confirm the symptoms of your Sony DSC-T1 camera and if found same, details are also there as Sony will repair it free of cost.
Regards,
Aug 05, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
52 inch sony rear projection
thats an lcd rear projection and that type of repair is better left to a professional but if you would like a service manual with free online tech support you can get one at the link I posted
Apr 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
292 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
