SOURCE: Aspect Ratio not responding/always in "Full" mode
i have a panasonic th-42pwd8bk tv i have it working through my sky box, but it only works in black & white no colour. it works in colour on my pc what am i doing wrong. i have no user manual
SOURCE: connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
SOURCE: Matsui 42" plasma TV
Thanks for the solution. A bit late for me I got so fed up that i went out and bought lcd 42" instead feel much happier with the quality of it. Plasma !!!! never again cheers all the same
SOURCE: Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
