Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
<!-- from fixya rte -->Why door hinge popping noise - Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Hello friend, thank you for your inquiry!
I see your door hinge is making a popping noise on your Frigidaire refrigerator. It sounds like the door hinge may need to be replaced or the door could use an adjustment. I would recommend contacting a professional to come out to diagnose the appliance to avoid any unnecessary part purchases. I hope this helps. -Matt
Posted on Sep 09, 2014
Tappan gas range oven door hinge is binding
What is the model number of the unit?
Nov 29, 2012 | Kitchen Ranges
The top hinge on my Kitchenaid refrigerator door is making a loud popping sound when the door is opened about 90 degrees. I removed the top hinge and it looks OK. Is the spring assist mechanism (that I...
You can easily go online and purchase the parts that you need... they usually come with replacement instructions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 15, 2010 | Microwave Ovens
When opening and shuting the door , the hinge makes a popping noise
You may have some worn door pin bushings, or the door hinge has excessive wear. I'm not sure if your vehicle has door pin bushings, if it does, they can usually be replaced.
Nov 08, 2010 | 1999 Jeep Grand Cherokee
When I open the drivers side door the hinge pops
oil hinges.check that door & front fender aren't rubbing.
Sep 23, 2009 | 2002 Saturn SC
I have a whirlpool gold side by side that makes aloud popping noise when opening and closing right door
Sounds like the door closer is bad or screw loose . Remove the top hinge cover and the 3 screws holding the hinge . Remove the food from the door first . After removing the 3 bolts , lift the door from the bottom hinge . You can tell by looking , if closers need replaced or if the screw needs tightening . If closers need replaced , both come in 1 package ( 1 for the door and 1 for the bottom hinge .)
Aug 09, 2009 | Whirlpool Refrigerators
Hyundai Elantra 2002 doors clicking and popping
Check the play in the door pin hinges by lifting up and down on the end of the door if there is excessive play or up and down movement the door pins must be replaced, I have had cars make this sound because of worn hinge pins.
Jul 14, 2009 | Hyundai Motor 2002 Elantra
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Door noise
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Apr 02, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
269 people viewed this question
Top Frigidaire Refrigerators Experts
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
