Question about Amana ARB2217CSR Bottom Freezer Refrigerator
How can I unlock wheels
Tell me how to unlock the wheeels \
The hand wheel is not moving the needle at all
Check the hand wheel. There should be a smaller wheeel in the center of the hand wheel. Make sure it is locked in(turn center wheel clockwise or could be counter clockwise til snug)
Rebuilted the front diff for 4 wheel drive. The light stay on and can't turn on 4 wheel drive How do I reset the 4 wheel drive to activate.
THE ACUATER IF ELECTRICAL YO SHOULD HAVE DISCONECTEDE THE BATTER BEFOR YOU DISCONECTED IT AT THE 4 WHEEEL DRIVE IF NOT THEN YOU WILL NEED TO REPLACE IT AS THEIR IS NOT RESET ON THEM. I HAVE DONE IT MYSELF MANY TIMES IN PAST.
4 wheel drive doesnt work
When you switch it to four wheeel drive does it sound as if the transfer case is doing what it supposed to do? (makes shifting noise) If so its probably the front differental actuator not locking in the front wheels. the part # is 12471631 through GM and costs $131.53, or through Schucks/O'Reily part # is 600103 and costs $85.99.
4helpful
2006 Grand Caravan I switch the turn signal on and turn the wheel, the signal does not turn off and I hear a clicking sound coming from the steering column.
it is the return cam located inside of the steering wheeel. Some are a part of the turn signal stalk and some are a part of the back side of the steering wheel.
4 wheel drive
Jack up the car from both front and back and when you start you should see all the four moving ,if its does then it a four wheel drive and only 2 wheels rotate the its in normal drive..........
Amana ARB2217CSR Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
