Question about Microsoft Xbox 360 Console
Disc tray problem
The drive belt for my disc tray popped out and is gone. Does anyone know how big the belt is supposed to be so I can see if I can make a replacement. MS wants $250 for the repair.
Posted by vdnovach on
  • vdnovach Nov 16, 2007
    Answering myself: I went to Walmart and bought a $0.98 pack of rubber ponytail bands and it now works like a champ.
  • vdnovach Dec 13, 2007
    My solution is cheaper!!!
Cary Farah
    President:
  • 4,402 Answers
Http://www.aedwis.com/
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Posted on Dec 12, 2007
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
My hp pavilion dv6-3025dx disc tray is jammed.
bad drive
replace it
or remove it, and service it.
things do break, and when that happens we replace them.
May 01, 2017 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
My dvd will not eject from my e drive
You can manually eject the disc by straightening a paper clip and insert it into a small hole just below the disc tray. Gently push the paper clip into this hole and the disc tray will unlock and pop out. You can now pull the disc tray until the tray is fully opened and this will allow you to remove the DVD disc.
Sep 16, 2011 | Acer (KV.16X04.007) DVD Drive
The drive cannot eject the disc
You can manually eject the disc by using a straighten paper clip and insert it into the tiny hole below the drive tray. Push the paper clip in the hole gently and the tray will pop out, then you can pull the tray open till it is fully opened to remove the disc.
Apr 24, 2011 | LG Computers & Internet
Disc draw will not open
Manually eject the disc tray
  1. Disconnect the power cord and any other cables connected to the console.
  2. Uncoil a paper clip.
  3. Position the console horizontally, as you would position a DVD player.
  4. Find the yellow sticker behind the vents on the left side of the console.
  5. Insert the straight end of the paper clip into the eject hole which is located just above the yellow sticker (as shown in the picture below).
  6. The disc tray should pop out slightly. Pull the tray out the rest of the way with your fingers.
Note If a disc is in the tray, make sure that it is not sticky and does not have a label that might prevent the tray from opening again in the future.
If you cannot get the disc tray to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Original Xbox 360 console: How to manually eject the disc trayFirst you need to remove your console's faceplate. Here's how:
  1. Unplug the power and A/V cables from the back of your console.
  2. Position your console horizontally, as you would position a DVD player.
  3. While holding your console firmly, push the faceplate away from the console with your thumbs.
    Note You will need to use some force to remove the faceplate.
  1. Uncoil a paper clip.
  2. If your console has holes below the right side of the disc drive, insert the straight end of the paper clip into the hole as shown in the picture below.
    If your console does not have the holes pictured below, skip to step 5.
  3. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
  4. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9. If the disc tray does not open, try the next step.
  5. Find the two holes below the left side of the disc drive, and insert the paper clip into the first hole on the left.
  6. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
    Note Make sure you are pushing the gear mechanism and not the metal plate.
  7. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9.
  8. If the disc drive is still stuck closed, insert the paper clip into the adjacent hole (to the right) and push again. If you're successful, the disc tray will pop out slightly.
  9. Now plug the power cord into the back of the console. Press the eject button to open and close disc drive. If the disc drive works properly, reattach the console faceplate.
If you cannot get the disc drive to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Xbox SupportPlease visit the following website for information about how to contact Xbox Support: support.xbox.com/pages/contact-us.aspx
Apr 09, 2011 | Microsoft Xbox 360 Console
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
My disk drive will not open dell Dimension 2400
It may have become disconnected from motherboard or power supply, but that is unlikely if the case has not been opened. It probably is either jammed, or the motor in it has gone out. If this is the case, you can find a fairly cheap replacement online. If you have a disc in the drive that you need to get out, you can use an unfolded paper clip, push it into the tiny hole on the front of the drive until the drive pops open. Manually pull the disc tray out and remove your disc. If it feels like it is off track, and you are up to the task, you can remove the drive, unscrew four screws and take the drive case off, and re-align the drive tray and this may fix your problem.
Jul 21, 2010 | Dell Dimension 2400 PC Desktop
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Disc won't eject
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Jan 19, 2008 | Teac (DW-224E) DVD Drive
I can not eject the disc tray
I too had a similar problem with my DHC FL7D. The front moving panel would not move up. The screen used to say 'please wait' endlessly whenever I pressed the DVD button. I thought the drive belt might have got cut. There is a drive belt for the front panel to move upwards and downwards. Since that was intact, I disconnected the front panel from the main body to access the DVD drive system. I had to disconnect many cables and PCBs to do so. Then I opened the DVD compartment and removed all the DVDs which were stuck and re-alligned all the disc trays to its original state. I checked if all the drive belts inside the DVD compartment, it was ok. Also I tried moving the laser lens assembly to check if it was moving. Since there was no problem I closed the system. <br />After I switched on it worked again . I think it might be to do with the fact that the disc trays might have been stuck for some reason or may be the there was a software glitch.<br />
Jan 08, 2008 | Sony DHC-FL7D System
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
