Camera cards are never to be formatted on the computer....only in the camera. "card error" usually always means you need to format the card in the camera. This will erase it so download any pics you want to save first.
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts.... Here's what you can try: Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad.Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon. Thanks
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts.... Here's what you can try: Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad.Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon. Thank you for using Fixya!
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
