Question about TuffCare Bariatric Hospital Bed, 1000 Lb.Capacity Bariatric Bed, T5000, 60" x 80", Complete Package
I need a tuffcare bariatric hospital bed users guide?
Posted by Robert Fitzpatrick on
Thomas Beaver
  • 2,119 Answers
Which is the best Dermatologist hospital in Hyderabad?
Continental Hospital is the best for Dermatologist in Hyderabad.
Today more people in Hyderabad suffer from long-term skin conditions - the most common being acne, eczema and seborrheic dermatitis, and sometimes all three at the same time.Check out: Skin Specialists in Hyderabad Continental Hospitals Dermatology in...
Feb 15, 2016 • Medical
What year was my hospital bed manufactured
The serial number will help you determine year and month on most manufacturers.
ie: MEDLINE SN# FLA 15 03 0215
FLA IS THE MODEL. 15yr. 03mo. 0215 production number
Sep 26, 2014 • Medical
3answers
What types of Hospital beds are there for rent?
There are many kinds that you can rent and I suggest that you search on google for rentals and see what is the best kind for you
Feb 14, 2013 • Medical
Where can I buy a hospital bed?
Try Medical Products direct: http://www.medicalproductsdirect.com/adjustablebeds.html
Electric control button raises the head of the Tuffcare hospital bed but will not lower it. It doesn't even make a clicking sound. All other functions are working through the control mechanism. Is there...
The problem you are describing happens quite often and there are several solutions.
1. The manufacturer sometimes supplies a manual crank that fits in the end of the motor to manually turn the motor and lower the bed. This crank is usually lost or misplaced (look for it on the bed frame). With the weight of the mattress and person off of the head you may be able to use a pair of pliers or other tool to carefully turn the motor shaft.
2. There is a bolt and nut at the end of the head motor shaft or a hitch pin and bolt. Remove this bolt at the end of the motor shaft where it attaches to the head frame and the head frame will drop to level.
3. Fixing the hand control usually involves taking the two halves apart and bypassing the push-button switch by shorting across the head down switch. This is the best way to diagnose a bad hand control. This is the most difficult solution for the average end user. You ultimately will purchase a new hand control anyway so this may be a viable solution. The hand control gets the most use and abuse and is usually the faulty part.
You may have a bad relay on the junction box control board where all the motors and hand control are plugged in. If the motor runs in one direction, the motor is OK. If you have the micro-switch style 6 button switch hand control you may be able to clean the switches by spraying contact cleaner is the switches and pushing them several times. Check the hand control plug for bent or bad pins at the control board junction box. The hand control pendant runs about $100 and the junction box controller is about $400. Hope this helps.
Apc surge protector and battery backups
you have to have the power rating rated in amps of the bed...if the rating of your bed and the system are same or even less than that..(i.e. the rating of television is less than that of computer monitor,so u can connect tv for long time than monitor when power goes off ) then u can surely use it.....but it ll provide the supply only till the back up is stored in the battery,when the power goes off
TuffCare Bariatric Hospital Bed, 1000 Lb.Capacity Bariatric Bed, T5000, 60" x 80", Complete Package Logo
Top TuffCare Medical Experts
Don A
Don A
ADMIN Canada
ADMIN Canada
Are you a TuffCare Medical Expert? Answer questions, earn points and help others
