Plumbing Logo
Question about Plumbing
Installing moen faucet on new tile countertop. Instructions don't say what size to make the holes.
Installing a new tile countertop and need to drill holes for faucet installation. Instructions do not say how big holes need to be. ( 3 holes)
Posted by Susan McFarland on
Dave Da Plumber
    Habit-Forming:
  • 38 Answers
Normally slightly larger than the valve bodies.
Posted on Sep 11, 2014
5 Related Answers
Steve Archer
  • 148 Answers
SOURCE: need instruction for installation pull out faucet
firs you have to remove the handle
remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
take a flashlight and determine if you need an allen head screw or phillps
remove the screw( be sure to cover your drains so nos small parts get in bottom
remove the handle
depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
whatever remove anything holding the cartridge down (some require a cartridege remover)
remove, take to store match up new and replace
by all means turn water of under sinnk good luck
TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
Posted on Jan 09, 2009
Anonymous
  • 10865 Answers
SOURCE: Installing TL794DD bathroom faucet
All faucets install easily if you have the proper tools. Answer these questions first: 1. how many holes are their in the surface of your sink? Is there a faucet installed now? If yes, you may only need to remove that faucet and use the same feed lines under the sink to hook up the new one. Take your faucet to the hardware store and ask the plumbing clerk if the hook ups under the sink are different from what your new faucet appears to be compatible with. good luck
Posted on Jan 18, 2009
Anonymous
  • 1605 Answers
SOURCE: hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Posted on Apr 06, 2009
Anonymous
  • 244 Answers
SOURCE: why would the side sprayer on my moen kitchen
Call Moen. Bad spray head or diverter.
Posted on Dec 18, 2009
john h
  • 28844 Answers
SOURCE: how to install the plumbing of a moen shower tap
the big round black plastic is part of the installation it will screw to the valve body thats the size of hole the black round cover is also backing plate to round external dress cover so be careful not much leway when cutting the center part should be knocked off but keep on to protect chrome escutcheon take off when applying handle also remember unit is shipped in cold position need to adjust hot water shipped in cold position because of anti-scald system
Posted on Jan 22, 2010
Testimonial: " Thank you for being so prompt. The information you gave me helped.Now that I know where to go for help I will use your web site in the future."
I need to drill a hole in my countertop to install my Glacier Bay faucet and want to know what size hole to drill
measure the part of it that goes through the counter here's a drill chart, there's a better chart below, can't read this one
Apr 17, 2019 • Plumbing
The base of the moen faucet is loose from the base it sits on
Usually there is a nut underneath the countertop it is mounted on. Probably just needs a good wrench tightening
Leaky faucet
This is generally due to a loose or faulty cartridge. To fix:
1. Turn off water supply valves under sink.
2. Block the sink drain to avoid losing small parts.
3. Remove faucet handle. It is attached by a set screw, an odd size (I actually used a T9 torx screwdriver successfully, even though the set screw is hex head, since I did not have a matching allen key). The set screw is quite far into the handle, ~3cm, through a hole in the bottom of the handle. Depending on your countertop layout, you may have to actually remove the entire faucet from the countertop in order to get access to it, in which case follow the appropriate parts of your faucet installation directions in reverse.
4. Remove dome. It will come off with a gentle turn/pull.
5. Check the tightness of the exposed large hex nut. This is the piece that holds the cartridge in place. If you are lucky, it is just loose, and that's your problem; otherwise you will need a new cartridge.
6. Unscrew that nut, remove. Pull out the cartridge.
7. Replacement cartridges may be found at your local Moen dealer, or may be ordered directly from Moen +1-800-Buy-Moen. Parts are free due to the lifetime warranty. Part #1255 includes the cartridge, cartridge nut, and set screw. The nut must be changed with the cartridge (presumably due to its wear characteristics).
To reassemble:
8. If you have it, place a very small amount of plumber's silicone lubricant on the back of the cartridge, on the rubber seals around the three holes.
9. Assemble in reverse order of disassembly. The cartridge only goes in one way, due to three guiding channels on its perimeter.
Enjoy!
1helpful
How to tighten mown faucet. Wobbles at base on countertop
There are screws that come up through the bottom. You may have to remove the faucet to tighten it. While you have it out, throw it away and buy a new one.
Getting ready to install the Moen DN2160 Curved shower Rod. In reading through the instructions I am confused about what is necessary to install in a tile shower
hi doug. the only issue with tile is that drilling holes in tile requires a special tile cutting drill bit. These are common. I got some last week at a home depot. J.
Jul 08, 2011 • Moen Home
No place to screw the faceplate onto
On your mixing valve, Your hot and cold water should hook to the valve at 9:00 and3:00 positions. You should have two ears at 12:00 and 6:00 positions which are used to screw the faceplate on. If you don't see these ears, the hole that the valve is in may not be big enough for you to see them. If it is tile, they may be covered with tile. If it is fiberglass, you would usually would have an oblong hole, longer at top and bottom, to see ears. If it is fiberglass, you may want to drill through where screws go, and through bolt your valve so it is tight. The hole in tile and/or concrete should be oblong so you can see screw holes.
Moen 3836...lost installation manual...what size drill bit for the hand held brkt.
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
Doe the mixer assembly for a show Moen 782694 get mounted flush with the tile or the backer board
usually flush with the tile. although moen does make an extension kit if you goof and set it too far into the wall
3helpful
How to install the plumbing of a moen shower tap
Moen shower faucet problem
I need to ask a few questions to solve your problem.
What Model Shower body is it?
How big is the white plastic piece?
If it is about 6 inches around (just smaller than the face plate) and you are installing this shower body in a preexisting tub/shower, this piece can be discarded. It is a guide that is used so the tile contractor knows how much room is needed to service the valve once it is installed.
If this is not the case, just post with a few details and I'll modify my response.
Nov 20, 2008 • Moen Home
Top Plumbing Experts
john h
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
