I just bought a new (craftsman 125 psi air compressor 1 hp 3 gallon) and when I got it home all it will do is hum every three seconds or so? It had NO oil in it as it was leaking from a long black cap. I got it stopped but could the pump be defective? It's also missing an air intake. Do I need to rebuild it? HELP!
SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
SOURCE: I have a 1.5 hp 3 gallon craftsman air compressor.
hi mate it is probably due to too much oil and when it starts the oil inside is splashed out the oil cap i reccomend start the compressor and let it run for 2 mins to get the oil warm take the plug out and drain the oil and the refill with p68 oil and on the oil sight glass refill it untill it reaches the red dot in the middle if it has one or on the dip stick it has a measurement good luck
SOURCE: compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
SOURCE: Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
SOURCE: craftsman 3 gal air compressor - no air presssure
Check the head gasket. Mine just did the same thing. Mine was blown between the two chambers on top. It's very thin right there. I went to the auto parts store and bought some gasket and made my own for about $6. It's up a working great...finally. BTW the gasket kit is on back order right now at Sear's parts website. It appears we aren't the only ones with the problem!
