Need to reset forgotten password
If you are talking about resetting your windows password please check out one of my previous question that I answered this might help. If you have forgotten your password.
http://www.fixya.com/support/t25071622-need_reset_password_medion_akoya_e1317t
This link should help you reset your password
SOURCE: Medion Akoya Multimedia notebook - wireless capability
I believe on the medion you have there may be a switch on the front or side to turn on the wireless. That or FN key and F1.
SOURCE: how do i override the password on my medion notebook laptop?
I assume you are referring to a system (hardware) password that you are challenged for when powering up the laptop, not the operating system password. You can just reinstalll the O/S into another folder to get access to the system and all the data files ...
Two types of system passwords exist;
1 type is the password stored in an area of the mainboard that is called CMOS (Complementary Metal-Oxide Semiconductor) a completely fancy way of saying an area whoes data is kept alive by a battery. You need to know if your model laptop uses a CMOS battery and how you can disconnect it. Go to the manufactures website at: http://www.medion.co.uk/ . If you can pull the battery for 30 minutes or so, then you may erase the password.
2 If you have a system that writes this password to a non-destructive area of the systems memeory in order to prevent data theft, you have a more difficult time removing the password. Some Lenovo systems must swap out the main board. the password cannot be accessed. Try the battery if you can, else Google medion laptop hacks
SOURCE: medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
Testimonial: " many thanks will get it looked at"
SOURCE: where is the wireless capability key to turn on
check your manual, but sometimes its on the front, some times its an f key ie F1, F2, ect this will have to be used with the fn key press fn + F? keys together.
hope this helps
