Question about Luxor Televison & Video
Luxor LED550FHD Wont start
Hello!, I have a Luxor LED tv that wont start, the led indicator is blinking and nothing else happens. I have tryed to push all buttons but nothing works. I belive the tv has been in the middle of a firmware update when the power got cut off, it says in the manual that if the power are cut of during a update the tv could be damaged. How can this be fixed do you think??, The tv was set to automatic update when the power was lost. worked just fine before and now I cant get it to work again. Is it a big fix or how do ypu think I should proseed with this?, I live in Sweden. Thank you! Best reguards // Aron Andersson
Posted by Aron Anderson on
Harrie
    Top Expert:
  • Luxor Master
  • 6,740 Answers
I'm afraid if the power was lost during the update, the TV has a real software problem. But you don't have the tools to put in a complete set of new firmware. When the TV is still working, the processor and the program can manage the upload to the memory and after a restart everything should work fine. But no perfect firmware in the TV now that can do the upload rot the flash memory. A technician has to connect the TV to a computer and flash the firmware manually.
The best thing is to contact a certified service centre from luxor and ask them.
Posted on Sep 06, 2014
  • Aron Anderson
    Aron Anderson Sep 09, 2014
    Thank you very much!, I will contact a technician and see if they can fix it. Its a rare tv here so i dont think there are many service centers who deals with Luxor. But I will give it a try!
  • Harrie Sep 09, 2014
    Don't look to the name on the outsider. Any tech centre should be capable of repairing the TV. But first ask them what they will charge, because the new ones are becoming cheaper and cheaper. And with a new one you get at least one year of warranty.
5 Related Answers
Anonymous
SOURCE: My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Posted on Jul 14, 2010
Benimur
Louie Role
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
Anonymous
  • 36 Answers
SOURCE: Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Posted on Aug 13, 2008
Anonymous
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: tv wont turn on. power button blinks
if your tv is blinking you are still okay but your set needs service, maybe some board or circut is defective. this happens with panasonics, they have a blink timer. they blink a certain number of times. this blinking feature is called safety mode, you find the part that is fualty according to the number of blinks, you can find out what fualty part is cuasing the tv not to go on by downloading a service manual in pdf format or finding the blink codes, how many times does it blink count it carefully i may have a manual here and maybe can tell you what to replace.
Posted on Jun 03, 2010
Were is the on button for a Luxor 32 in tv
Hi Vic
From what I can gather on the link below (page 17), the on/off button appears to be on the back panel left side. Push the centre of the button for two seconds and you're good to go.
Hope this helps.
-Steve
Manual Luxor LED32CX LED Television
Jan 19, 2015 | Luxor Televison & Video
Ibm x3400 is not powering on green led blinking continiously
Hello here is others with the same problem:
http://www.ibm.com/developerworks/forums/thread.jspa?threadID=397434&start=15&tstart=0
It looks like the power button is failing.
The fault could also be the mainboard.
Try also to talk with a autorished dealer or a repair shop.
Good luck
Dec 15, 2012 | IBM x3400 Server
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
Blinking on learning indicator...push the remote or wall button nothing works...what happen?
If that LED is blinking a code let me know what it is. For instance 5 blinks and a pause then repeats. If it is just blinking randomly that is normal.
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Wont turn on
I have the same problem. When I push the green button nothing comes on - just the green LED keeps blinking.....could you manage to find the solution
Sep 28, 2008 | InFocus User guide, LP500 / 530 Projector...
Operating tv
there is a short inside the set, count the times that the led blinks before it pauses and let us know make & model number of set, model # is on a sticker on the back of the set, with that info and the blink code maybe we can help you out
Nov 28, 2007 | Televison & Video
56DR650 Wont Turn on
I have a problem occasionally because the color wheel won't start. It has a bearing problem and is very noisy.
Nov 20, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Televison & Video Logo
1,013 people viewed this question
Top Luxor Televison & Video Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
