The wire thats inside of the headlight assembly that connects to the bulb has a broken wire and has power coming from it.I bought another one but need to see how to get to it so I can take it out and replace it
SOURCE: Fix Brakelight on Chrysler Crossfire 05
They Are Removed From The Inside. On The Inside Of The Car Find The Opposite Side Of Where The Light Is. There Will Be Either Carpet Or A Panel There Remove That And It Will Give You Full Access To The Lights. Use A Twist And Pull Motion To Remove The Light From Its Housing Then Replace The Bulb.
SOURCE: replacing headlight bulbs on a 2006 chrysler sebring
Behind the headlight you should see a eletrical wires running to the headlight section. There will be a 2 inch round plastic ring. You grap the back of the bulb and turn it to the right which will release the bulb and the socket. You pull out the bulb and replace it the same way. If this doesnt help then get back to me.
SOURCE: Replace headlight bulb on 2005 Chrysler Sebring.
No again. there are 2 9/32 bolts above the light assembly, remove those. One is long one is short. After removing those, the assembly can be coaxed out where you can access the bulb. It goes back in alot easier.
SOURCE: I have a 2004 chrysler crossfire and the key is
Please go to: http://www.crossfireforum.org/forum/tsbs-how-articles/33074-sticky-ignition-key-fix.html
SOURCE: 06 chrysler 300 wiring harness diagram
Need color wire diagram to bypas the ignition transponder. I have the module and the chip key.
When a headlight burns out on your Chrysler
Crossfire, you do not need to rush to the repair shop to have it
replaced. You can access the headlights in your Crossfire from within
the engine compartment, allowing you to change the headlight yourself.
The Crossfire uses an H7U headlight bulb, which you can find at auto
parts retail stores or at a Chrysler dealership.
Difficulty: Easy
