Question about Samsung 32" Class 1080p 60Hz w/ 120CMR LED-LCD HDTV UN32EH5000F
Samsung users manuals
Have 3 TV's on air antenna. Have lost channel 5 on Samsung. How do I get it back?
local repairman in ELECTROMAX service
    New Friend:
  • 68 Answers
TUNING MANU CHANEL SETINGS MANUAL AND 5 ON REMOCON TOO THE PLACE FOR CHANEL NO
Posted on Sep 28, 2014
5 Related Answers
Anonymous
SOURCE: Lost ITV channels and C4
I have the same problem, can anybody help?
Posted on Jul 08, 2008
Anonymous
SOURCE: My Samsung PS42C7S Plasma TV suddenly lost
my samsung plasma 50" tv has no picyure just sound, it is only 2 years old
Posted on Jan 24, 2010
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: i lost the 3 screws for the stand of samsung 32"
6mm thread no more than 10 mm length
Posted on Oct 29, 2010
Anonymous
SOURCE: icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Posted on Nov 14, 2010
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: How do I manually/automatically update the
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Posted on Jan 07, 2011
Samsung TV loss of signal. Our Samsung tv has lost all free to air channels.
try setting the right IP configurations if that is the error reported
May 16, 2016 | Samsung Televison & Video
Can't get Digital TV (freeview)
Change the input to antenna.
If it says cable:
On your Samsung remote is a button that says antenna. You want it to say AIR. Air is an ATSC tuuner that allows you to receive over the air HD with a pair of rabbit ears.
If it says AIR:
If it says AIR and you still can't get the HD channels. In the menu it will say Channel. In that sub menu it will say autoprogram. Make sure you have an antenna connecte to AIR in the back of the set and autoprogram AIR only.
Any questions respond to this post and I will respond.
Jan 12, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
How do I find a video to hook up my Samsung TV? Model BN68-04027A-03 The TV was a Xmas gift and did find a video and now I can't find it Tx. Wanda
The English owner's manual for the part number listed is available at...
http://www.manualslib.com/manual/146620/Samsung-Bn68-01171b-03.html#manual
Page six (6) indicates the back panel of your Plasma TV has two HDMI inputs, one component (RGB) and a specialized AV input/output connector. The latter requires a cable that is popular in Europe. Adapters to use it with US standard S-Video and RCA composite video are difficult to locate.
HDMI and component cables are available at big box stores (Best Buy, WalMart etch) but are much cheaper from generic internet sellers.
I am not sure about the second half of your question concerning "get to channel 3 to get to all other channels).
I must assume you have told the TV to "scan" for other channels (cable or over the air (OTA) with the black antenna/RF cable connected directly to the back of the TV.
If you have done so I am guessing you have connected the antenna cable first to a RECORDER or CABLE BOX. In many cases, these will only output channel 3 or 4 and block all other channels when turned on. In order to see other channels, you will need to buy a 2-way RF splitter so that both the recorder or Cable box can be connected at the antenna cable at the same time. Please note, doing so will mean you cannot see the output of the recorder or cable box on channel 3 or 4 but must use its the video/audio (HDMI, component, composite, S-Video) outputs from it to the TV. Again, this splitter is available from big box stores or the internet.
Jan 05, 2015 | Samsung Televison & Video
Samsung User Manual Samsung UE32F5000
Series 5 32" Samsung F5000 Full HD LED TV User Manual:
copy this link into your internet browser to see:
http://downloadcenter.samsung.com/content/UM/201303/20130307133547049/[WEB]X13DVBEU1F-ENG.pdf
Aug 17, 2013 | Televison & Video
Need owners manual for flat screen samsung LN32B36065D. having problems with televsion. no manual with tv when purchased.
Hello
To which model Samsung TV do you want to get the user manual? You have here stated two models of Samsung. If it is for Samsung LN46C630; I've the manual with me. If you send your email address to me, I'll send a copy of it to you by return mail. There is no model Samsung LN32B36065D with Samsung website. OK.
Jun 15, 2011 | Samsung LN46C630 TV
Displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Feb 23, 2009 | Samsung Televison & Video
2 y/ old Samsung DLP TV (HLR6167) - no sound
your problem is most likely not the Tv i bet you are using an air antenna arent you
Feb 16, 2018 | Samsung HL-R6167W 61" HDTV
On the converter box that we hooked up we are geting every channel except 5-1 5-2
Any -1, -2 channles considered as a off-air antenna channels. I assume you have the off-air antenna and good reception on it. So make sure your off air antenna hooked up to your receiver.
If everything is hooked up right and your reception on antenna is good, try to trace the line for your antenna. may find any visual problems such as loosen up, dog chewed the cable etc :D
Last thing if you don't find solution by yourself is call your service provider for service call.
Good luck
Oct 19, 2008 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Samsung 32" Class 1080p 60Hz w/ 120CMR LED-LCD HDTV UN32EH5000F Logo
167 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
