Question about Yamaha Electrical Supplies
What are torque settings for head bolts bolts
Head bolt specs
5 Related Answers
chuck943
Chuck Martin
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
Anonymous
SOURCE: 3 cylinder kubota , head bolt torque specs
I have similar problem, trying to find the tappet clearance for engine D850. Try pasting this link in, might help ya some. http://www.tractorsmart.com/KubotaEngineSpecs/Kubotadieselengineoverhaulspecifications.htm
Posted on Jun 07, 2009
Anonymous
  • 1392 Answers
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Posted on Aug 16, 2009
outdoorsman5
outdoorsman5
  • 631 Answers
SOURCE: head bolt torque specs for 2000 dodge neon 2.0 SOHC
I have the specs and diagrams. If you want me to send them to you, give me your email address. [email protected]
Posted on Sep 05, 2009
Anonymous
  • 384 Answers
SOURCE: torque specs for 1998 26hp kohler head bolts
I use 150 ft lbs on my racing 2-cycle engines, tighten in a star pattern.
Posted on Sep 16, 2009
Head bolt torque for ir. ss5 air compressor?
It's not that critical, use a torque wrench and make sure they are all evenly tightened like you would do with the head of a car engine. Use basic torque specs for the size bolt. That can be googled. Start with a lower setting on the torque wrench. Tighten the bolts in a pattern, then increase the torque setting and torque the bolts again.
May 20, 2016 | Ingersoll Rand Air Tools & Compressors
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Toyota 2c. I need cylinder head and flywheel Torque settings
Toyota 2c ...
USE NEW BOLTS...
Torque sequence:
You're driving a diesel single cylinder head engine. Engine head torque has to be done in specific order and stages if not can warp head or break bolts. Suggest you get torque sequence and torque specs from your Toyota dealer, they can give you correct answer. Don't trust answers on here, if you choose wrong specs. could end up messing up head.
Flywheel - Use a Sealer on bolt, Manual Transmission 88nm/65 ft lb... Auto Transmission 74nm/55 ft lb
Aug 06, 2014 | Cars & Trucks
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
I need the head bolt torque specs for a 94 bonniville with the 3.8l v6
A few notes. These head bolts are what are called torque to yield, this means they are like a spring and are only used once or the torque spec is not valid.
1ST 37 ft/lbs + 130 degrees OF BOLT ROTATION THEN REPEAT WITH 30 MORE degrees OF ROTATION. there IS NOT A SET TORQUE SPEC IN FT POUNDS
Feb 15, 2012 | 1994 Pontiac Bonneville
2)back off 1/2 turn
Aug 16, 2009 | 1999 Ford Escort
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Head bolts torque settings
According to my haynes manual for G-S reg, 1989-1998 it goes as follows,
Stage 1:- Tighten all bolts by hand until bolt heads just contact cyl. head.
Stage 2:-Tighten all bolts to 40Nm or 30lb ft.
Stage 3:-Angle tighten all bolts a further 60 degrees.
Stage 4:-Angle tighten all bolts again a further 60 degrees.
Stage 5:- M12 x 140mm bolts ONLY angle tighten a further 20 degrees.
Hope this helps everyone, sorry it seems longwinded but that is how it's written in the manual.
Oct 26, 2008 | 1995 Land Rover Discovery
Electrical Supplies Logo
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
