Sony bravia problems
I have just installed a Brand new straight out of box Sony Bravia and it has a White line approx 3cm wide right down the centre of the screen, is this a case of back to suppliers.
Chris Frost
  • 985 Answers
Yep.
Posted on Sep 07, 2014
5 Related Answers
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: Airsoft gun hit Sony Bravia LCD screen, can this be repaired??
Yes but not cheaply
Posted on Aug 10, 2009
Anonymous
SOURCE: 12 little horizontal lines in Sony Bravia KDL-52W4100
we have the same exact tv and it is not even a year old. we are told that it is the display panel and it is a well known problem with this tv. we were also told that there is a shortage of these parts. they had 283 on order, but only received 35. you need to call sony and tell them that you have this problem. they should warranty this for you even if your tv is 3 months past the warranty period. since this is a well known problem with this tv, keep on them.
Posted on Nov 24, 2009
Testimonial: "It in fact was a part of the lcd panel...the t-con board. I was able to research it and bought a box of parts off of a tv like mine and fixed it. Ron"
Anonymous
  • 68 Answers
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Posted on Nov 28, 2009
Anonymous
SOURCE: horisonal line across sony bravia kdl52w4100
i have lin down ma tv
Posted on Mar 01, 2010
tvhelp-Dave
Shukai Fung
  • 178 Answers
SOURCE: sony bravia kdl40S504 has green ghosts - cannot
I do not think that cause by power surge, and it is on manufactory warranty, you better to call Sony.
Posted on Jun 26, 2010
My sony bravia has a number of fixed thin red lines in the centre about 8 inches wide, whaty can I do
LCD driver or LCD data processor failure. it can be resolve by replacing the LCD panel.
Feb 04, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
PAIRS OF GREY MARKS GOING DOWN THE CENTRE OF MY TV
YOU HAVE A PROBLEM WITH THE LCD PANEL. SONY DOES NOT CONSIDER THIS AN ISSUE AS NO ONE WATCHES A WHITE SCREEN.
Jul 17, 2009 | Sony Televison & Video
I have a 4 month old sony bravia 1080 120mhz Sony
Not common but electronics are electronics , we can have failures right out of the box. Generally Sony is reliable and I must say that you should not have to worry about cost , Is it not under warranty - its only 4 months old !!
May 13, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia 42" Horizontal Lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 19, 2017 | Sony Bravia KDL-42V4100 42 in. LCD TV
I have a Sony Bravia KDL-32v2500, 16 months old, a thin vertical green line has appeared just off centre. It is on all channels and all input sources. Any suggestions?
If it still under warranty, no cost will be there, but if its out of warranty, you have to pay to Sony (might be they give you some discount) because its problem in LCD Panel.
Aug 05, 2008 | Televison & Video
Vertical Lines of Sony Bravia 46
IT CAN BE FIXED BUT NOT BY YOU
BOARDS NEEDS TO BE REPLACED OR RIIBON CABLES NEED TO BE RESEATED. YOU CAN DEAL WITH A SERVICE COMPANY(NOT ALL ARE AS GOOD AND KNOWLEGABLE AS THE ONES YOUR READING HERE)
OR EXCHANGE IT
YOUR CALL
Feb 21, 2008 | Sony BRAVIA KDL-46V3000 Television
Televison & Video Logo
550 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
