Hello, how to update the firmware when print aka EPSON AL-M300 isn't recognise on PC W7...? Thanks for informationsHello,
You can't post conmments that contain an email address.
When the printer makes and update cancel the installation of new drivers, or cut the power when the drivers are installed. Wait 10 seconds them power up the printer.
To install your device, just use the CD or DVD provided with it. Just run the CD and then the Autorun program within will run. Install the program and restart your PC.
If there is no CD/DVD available, go to the below link and download/install the required softwares/drivers.
This is a pain in the **** but after reading this info you should have success. It is important to note I had many installs and may restarts and eventually the program just started to work.
Go to http://support.g7ps.com/download/ There is a file: M300 Vista Patch (ISO to burn a new CD)
cdvjm300.zip
Download this and then you need to get it on a CD. It is in .iso. I downloaded winimage.com to open the iso file. Search the web for a program to open .iso files. After extrancting this to a CD you will have all the data on CD in original form.
Double click on the CD and the setup should automatically start. I did not install the 4XUltrasaver software. In Control Panel make sure the printer shows as M300.
I am using My Checkbook to print checks and it works LOTS better than Versacheck (YUK!!)
I spent 4+hours on this and there is probably a better way but this seemed to be the easiest in the end. Please add to this info as you find an easier way and the world will be a better place.
hi there
here's the link you need
http://www.dynexproducts.com/t-drivers.aspx
just click on DX-M300 link download the .zip driver unzip it and it's ready to install
as easy as that
good luck
