Washer will not fill or agitate in wash cycle. Washer will agitate in spin/rinse cycle?
I have found that these links do not always tak you to the same page that see.
Go to www.searspartsdirect.com/ and enter your model number.
Manuals and parts diagrams here.
Maytag Laundry Parts Model LAT9593AAW
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-LAT9593AAW/3048/0153200
Two links for youtube videos.
https://www.youtube.com/results?search_query=maytag+top+loader+will+not+fill+or+agitate
https://www.youtube.com/results?search_query=maytag+LAT9593AAW+won%27t+fill
Posted on Sep 06, 2014
SOURCE: maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Posted on Nov 15, 2007
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it. Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
SOURCE: Kenmore Washer 110.26912690 series 90
Hi Norm. Welcome to FixYa.
The first thing to check with the kind of symptoms your machine exhibits is the operation of the lid switch. Make sure that the pin/plunger on the lid itself has not broken off, and check the actuator lever on the switch itself. It is REALLY common on your model for the actuator arm to break off or crack, and this will cause no spin/no pump problems. Your machine is built by Whirlpool and the part number for the switch assembly is a 3849238. You can get it at any local whirlpool parts center in your area.
I hope you find this info helpful and thank you for allowing us to serve you.
Happy New Year from the FixYa crew!
Posted on Dec 27, 2008
SOURCE: WASHER WON'T WASH
Check the pully Cam if thats good. You have a bad tranmission. This warr. for ten years
Posted on Feb 10, 2009
