Question about Insignia IS-LCDTV32 32 in. Television
Why hmdi cord wont connect
Wont display from my pc to the tv works fine in the beginning but at start up cuts off
Posted by Timothy Jones on
Can't get picture after hooking ps3 up to jbc hd-56g647 by HDMI cord
If it works on another TV, make sure the correct HDMI port is connected.
Jan 09, 2015 | JVC HD-56G647 Compatible TV Lamp
Hello i bought a sound bar its a phillips cant get any sound out of it tried another tv same thing
Most sound bars are connected from the TV via the audio output. Try connecting out from tv with Toslink or optical cable. This should operate all of your tv audio.
Jan 03, 2015 | Toshiba Televison & Video
Computer to tv
just connecting is not enough to view pc on tv, you need to switch the display by pressing the fuction key, diffrent on each system
Jan 08, 2013 | Compaq Computers & Internet
Hmdi connect from PC asus to vizio tv No signal
did you tried pressin the FN key and F4 or F7
May 03, 2012 | ASUS Computers & Internet
How do i connect my gateway 509GE desktop to my hd t.v.
Does your PC have either a DVI or HMDI video connector on either the motherboard or the graphics (video) card? (In other words somewhere on the back of the machine?)
Does your HD TV have a DVI or HMDI connector on it?
If the answer to both of these questions is yes then you can do it.
Most peoples first choice would be to use the HMDI connectors. If you wish to do this you will need an HMDI cable.
If you decide to use the DVI connectors then you will need a DVI cable.
If your PC doesn't have either the DVI or HMDI outputs then you will have to buy a graphics (video) card for you PC. Be sure to get the appropriate cable also.
Once you have the HD TV connected to your computer you will have to use the graphics card's software to set things up. If you right click in an empty area of the desktop this software should be one of the choices in the menu.
HTH
Jun 16, 2011 | Computers & Internet
I have hmdi cords and I am trying to get the tv to turn to 1080I how do I do that
This Sansui HDLCD-1900 can only do 720p MAX. The source will determine the display resolution, you do not set it at the TV, just like you do not set the PC monitor resolution at the monitor, it is done at the PC. http://reviews.cnet.com/flat-panel-tvs/sansui-hdlcd-1900/4505-6482_7-33089579.html
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 21, 2010 | Sansui HDLCD-1900 19 in. LCD Television
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
My dell 531s wont connect to internet
Fresh install of operating system/ updated drivers may help if all else fails try to get another ethernet card and stick it in there and see if it connects..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | Dell Inspiron 531s Desktop Computer
Insignia IS-LCDTV32 32 in. Television Logo
147 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
