Question about Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW
How can i reset the toner on a brother mfc9340cdw printer
Posted by Deer Ridge on
Erroll Brady
    New Friend:
How I Reset My Brother MFC9340CDW Series Printer on 12/3/17
First you should make sure that the printer is turned on. Then the following steps should be performed :
i. Open the front cover. With the front cover open, the LCD should
display "Cover is Open".
ii. Hold the the # and the * buttons down for 5 seconds until Reset Menu is displayed.
iii. Press the UP ARROW until TNR-STD-(X) is displayed where X={K for Black, Y for Yellow, etc.}
iv. Press the OK button.
v. The LCD will briefly display "Accepted".
vi. Close the front cover.
The printer should start working after following the above process.
Posted on Dec 06, 2017
ctnozil
    Champion:
  • Brother Expert
  • 270 Answers
Auto detect if it is a new original toner.
Posted on Sep 08, 2014
Replaced waste toner box. Continue to receive "Replace Toner Box" message. Have insured that all parts back in properly. Will not print.
There is normal a clear plastic section on most waste toner boxes that tell the printer / copier how much toner is inside check to make sure it is clear! Dump the toner out if you don't have a new one BE CAREFUL CAN GET VERY MESSY. DO not use water to clean up use vacuum but do be care toner particles are small enough to go thru some vacuum filter so try some small amout make sure it does not spray your wall! Also check make sure the toner box does not have any broken small tabs the indicate to the printer thr the box is properly installed, one other check if the box has clear section match that section in the printer and clean that area sensor the monitors the clear section may have toner in it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 22, 2015 | Brother MFC9340CDW Wireless Printer...
Brother MFC not printing in color
go into printer properties and set the colour as default.
normally when you go to print something there is a tab section that will get you there before you actually press print
May 24, 2015 | Brother Wireless Color Laser MFC-9340CDW...
Default passwords
If you contact the manufacturer, they should be able to provide this needed default password. Best Wishes
Sep 01, 2014 | Brother Wireless Color Laser MFC-9340CDW...
Brother DCP-9020CDW - How can I reset the toner life?
Hi there
You can reset the brother dcp 9020cdw toner cartridges using the printer menu. Its simple. see video on the link
http://www.zinetic.co.uk/Blog/resetting_the_brother_dcp_9020_cdw_toner_cartridges-blog.aspx
Nov 18, 2013 | Brother DCP-7020 All-In-One Laser Printer
Brother 9970cdw toner
The Brother printers have a counter which will shut the printer down when the preset number of copies has been reached. You can reset the counter and it should print again. I did this 4 months ago. It bought me a little time, but my printer has begun to print a solid line down the left side of each page. I have cleaned everything that I can access to rule out smudged glass, etc. Perhaps it is just best to replace the drum or buy a new printer(much to Brother's delight and design).
Jul 10, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother 5250DN Printer Toner light
Try resetting the toner counter manually;  * Turn off the printer and open the front cover * Press and hold the Go-button down * Turn on the machine while still holding button down, when all three LEDs are lit, release Go-button * Press the Go-button twice, and all three LEDs should be lit again. * Press the Go-button five times (six times if you have the High Yield toner) * Close the front cover and the toner counter should be resetted.
Jun 02, 2009 | Brother HL 5250DN Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW Logo
439 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
