Question about Kitchen Ranges
Gas oder when using oven, not when using burners. stove well over 14 years old.
Serial #29695518QQ
Ronald Rissel
    Master:
  • Kitchen Ranges Master
  • 713 Answers
What brand is it? Does the oven use a glow-bar ignitor, or a spark ignitor. I'm assuming it uses a glow-bar ignitor, and that ignitor is weak and needs to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Posted on Sep 21, 2014
5 Related Answers
Tony Coultrip
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
Anonymous
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
bozcro
bozcro
  • 867 Answers
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Posted on Jul 30, 2009
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
The pilot light on my caloric gas oven lights, but the oven burner doesn't light. The oven is old, but only used for 2 months before being put in storage for 13 years. The stove top burners work fine,...
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
Nov 26, 2009 | Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Gas range..surface buners light...oven does not.
Usually the gas valve is behind the stove. pull it out from the wall and look behind it. Code requires the shut off valve to be in the same room as the stove so if there is no shutoff valve it would be a good idea to call your gas supplier and have them take a look at the problem. They will look at it and advise you for free.
Mar 31, 2009 | Ovens
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
