Question about Hotpoint Refrigerators
Is it ok to sell a new faulty fridge through a large retail outlet
Hotpoint put into a retail outlet a fridge which required a modification. They did not recall these fridges but waited till they broke down. The retailer sold this fridge which then breaks down customer complains . Engineer is sent out with modification. Everytime retail customer goes away on her return she has to throw away all the rotted food. This has now gone on since July 2013.
Posted by John Elliott on
J Rosado
  • 1,183 Answers
Complaints should be made known to consummer affairs by every customer involved.
Posted on Aug 24, 2017
5 Related Answers
Anonymous
  • 55 Answers
SOURCE: Fridge smells
Are there any drip channels in the back or bottom of the interior of the unit that may be clogged? These channels collect condensate and feed them to a pan under most refrigerators. I assume you have removed bottom food storage drawers and cleaned inside. Also try open box of baking soda which absorbs odors.
Posted on Feb 27, 2008
22yooper
James Helmer
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
douglas smith
  • 1462 Answers
SOURCE: Faulty Hotpoint Fridge Freezer
past rulings under the sale of goods act is that if product has lasted a year, then it is of merchantable quality - you are unlikely to get a full refund or free replacement even if you went to arbitration.
but what was wrong with it that your engineer deemed it to be uneconomic to repair?
remember that finding a good refrigeration technician is not easy
Posted on Nov 26, 2008
Anonymous
  • 40 Answers
SOURCE: frezzer works but the fridge does not keep any
If the appliance is nofrost and new keep the air outlets open do not put food infront of them.this can dramatically effect the performance.If it is an old appliance which runs for a while correctly but this happens check the flap is functioning correctly.You can do it by open the fridge door press the door switch button put your hand to the air outlet if it air comes after a while it funcitons if not that means flap is malfunctioned or blocked.empty the appliance leave doors open for 12 hrs. restart if not function no way change it.
Posted on Jun 30, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: Food freezing in Hotpoint refridgerator
Hello, Your problem is going to be with your cold control/Thermostat this can be located in the control console inside the refridgerator. This part needs to be replaced, the part number is WR9X10042 Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike
Posted on Jul 24, 2009
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
I have a hotpoint fridge bottom freezer and after I had filled the freezer with my shopping yesterday, it started making a shreeking noise, I thought maybe it needed defrosting, which it did, so I...
If both section are not working as required then its compressor fault.The noise you noticed must be from compressor related parts,that are fan,the motor and relay.But If freezer is getting over cold and friezed and fridge section not getting cold then Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Hotpoint FFA45 Bottom Freezer Refrigerator
My Hotpoint Refrigerator keeps popping the outlet breaker and shutting off. I took the rear vent grate off to clean any dust out and noticed there is about a 1/8" of water sitting. Is this what could be...
Normally if the fridge is tripping the circuit breaker, it is due to a short caused by the defrost element.
However, the second problem could be caused by a faulty timer.
Ash
Oct 22, 2009 | Hotpoint Refrigerators
Hotpoint fridge freezer / howdens kitchen - no instructions!!
Luckily the hotpoint helpdesk admitted that the instructions for hanging the kitchen doors does not come as part of the standard instructions. There should be a seperate piece of paper with these instructions.
After some to'ing and fro'ing they managed to email me the required diagram.
Feb 05, 2009 | Refrigerators
My electrician is here to do the electrical for my new Jenn-Air Gas stove Model # JGS8860BDP.  The store said we need both 110 and 220 outlets inside the stove space.  My electricial doesn't think...
Trust the Electrician. 99.9% of the time, the only requirement for working at a retail store is to know absolutely NOTHING of the product they sell. Where an electrician is liable for any damage to property or person injured due to his/her work... not to mention to 2 years of required training to get your journeyman lisence.
Jan 13, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Nov 26, 2008 | Hotpoint HTM17BBSSA Top Freezer...
Meade telescope focuser missing
ebay, cloudy nights classifieds, are good places to look, i used an anteres crayford focuser for a 8" newtonian. this did require some modifications to the tube.
Apr 16, 2008 | Meade Infinity 114EQ-DH Telescope
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Refrigerators Logo
56 people viewed this question
Top Hotpoint Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
peter gittos
peter gittos
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
