Are the faxes from the same person or different people?
(I have to ask, remember I don't know how much knowledge you have.) If yes, it could be on their end.
Does it do this with copies also? If yes, May be dust on the mirror or
something in the printer getting in the way of the laser.{slight possibility].
How many prints are on the printer? Could be a fuser issue.
Turn the printer off.
Do not try force the carridge unit while the printer is on.
This will damage the machine.
There are clips on the sides of the carridge unit
that will need to be pryied open.
Please do not use to much force as the clips are plastic and can easy be damaged.
Slowly wiggle the cartridges out
Hey!Press menu and the # key,It will say on the display 1 sssw!Use the aroows right and go to report and press set/ok!Use the arrow again to go to system dump and press ok/set again and it will print the report with the totals on!!Good Luck!
hi check your cartridge number are ok , clean the pin points of the cartridge and carridge pins of the printer if not works , try another cartridge if not works than may be carridge faulty , carridge data cable faulty, or logic card of the printer go to your service center or any repairing shop .
your carridge unit must be full with ink you have to clean the carridge unit if you can do ur self clean the ink otherwise take to near by service center just ask to do service only
