Vehicle Parts & Accessories Logo
J
Jerrie cirillo Posted on Sep 05, 2014
Grinds in coffee cup - Vehicle Parts & Accessories
tav40tez
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Sep 05, 2014
tav40tez
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
2807
Points
32
You're putting to much coffee grinds in the filter. Or to many filters. Or drain cup plunger is not open enough to allow water through like when it was new. If this is happening, water is not getting out and bowl is filling up fast pushing water over the filter and down the sides of inside of cup, finally through the plunger. After u make coffee and replace the old filter look in cup. If you see grinds then you will now know.
The coffee grinds are coming out the top of the coffee maker like its not sealing on top of the k cup
I would take out the part that holds the k-cup, take the bottom part apart and reverse rinse it out. There is a small filter right at the bottom and it sounds as if your k-cup is not filtering fast enough
Need to make about 15 cups of coffee, how much coffee and water I need?
Equal amount of water per cup = 15..
About 2 heaping table spoons per cup = 30 tbl spoons.
I also add ground cinnamon right on the coffee grinds
before starting coffee maker
In the last couple of days our Keurig has been giving us lots of grinds. One entire cup was fllled with them while others have them floating. We use the K-cups from Keurig shipped to us. The coffee...
Hi,The bottom needle is plugged so the coffee is running back out over the top instead of going through the bottom needle...use a paper clip to open it up...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
2helpful
My Saeco magic grinds the beans, but no coffee comes out. Sometimes it makes one cup, and skips. Other times, I grind the equivalent of 8 cups of coffee without any cups of coffee coming out.
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
1helpful
Cusinart 12 cup grind and brew overflows with grinds and water
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Coffee grinds on K cup holder
try removing the K-cup holder and inspecting the bottom hole opening. This is where the bottom of the K-cup holder would go through. Sometimes grounds can rest on that edge and fall into the coffee. I hope I could help!
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Water/grinds spillover in coffee basket
Pot must be inserted with the handle pointing straight out the front so it will hit the valve that is below the basket designed for the "rob a cup" while brewing feature.
Calvin
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
