Question about Acer Computers & Internet
Black border on all sides of screen, reduced desk top all on windows Vista
ICONS ARE ALL SHUFFLED UP AND ALL PROGRAMS OPEN VERY SMALL.
club98dj
  • 163 Answers
Right click on your desktop screen and click screen resolution,click on resolution and try a different setting.Keep changes and click apply.If that helps,keep trying different resolutions until your desktop is right for you :)
Posted on Mar 17, 2016
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: Sometimes when I change the
All LCD displays have an "Auto" button press it and see if that fixs it. should be aparent what it does if it does it. but basicly it alines the picture with the screen. when you change back to user profile you may need to press it again.
Posted on Dec 26, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Hello, I have a 22
i would go to asus or computer manufacture's site, or microsoft and find and download the driver manually. Then install it by double-clicking the downlaoded driver file.
I also recommend right clicking on screen, go to properties or display properties, and only use the windows 7 them and not a modified or customized theme.
Posted on Jan 30, 2010
Pulkit558
Pulkit Tigrania
  • 472 Answers
SOURCE: screen is not centered horizontally
each monitor has a different settings so please check your monitor settings.
If your monitor has a reset option than press it and your screen will get fine by itself otherwise you'll have to change the settings manually
Posted on Feb 26, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Desk top appears for short second and then screen
First, does it do the same when used with another PC?
Pictures: http://s807.photobucket.com/albums/yy352/budm/Acer%20X223W/
You will need to 1) inspect the DC filter caps for any of them with domed tops, 2)then check the DC voltages as shown, 3) You need inverter tester (lamp assemblies to find out if the lamps or the inverter board is bad).
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 08, 2011
Curser want move my screen i show two sets of icons on my desk top
You probably have a two dekstop's. One as a single user, and second for common use. Try to re-locate "Desktop" folder to new location with better control. (use regedit)
Apr 17, 2014 | Computers & Internet
When I turn my laptop on the desk top with the start button and other icons together with material I have saved on my desk top are not shown. The screen is blank and black
reboot it in safe mode and if it shows desktop restart once again
booting in safemode hold F8 while restarting your machine choose start window in safe mode and hit enter
best of luck
if problem wont solve let me know please i will tell you another way
Aug 19, 2011 | Computers & Internet
I could not get my sylvania netbook to connect to my wifi so i download the update from their website to a SD card then opened on the netbook and it deleted everything on the netbook. how can i restore it...
I do not know why your icons disappeared by running the Download, but your programs are still in the on board ROM memory and what you are missing are your desk top icons. I have tried to duplicate your download problem but so far have not been able. I know that using a SD card will not download a usuable file so I used a thumb drive.
Any way please read the following solution that I wrote to another poster.
If you have deleted the icons for those programs on your desk top, then they may be in your Recycle trash bin. double click on Recycle Bin look for the icon for recorder, right click on recorder and select restore. You really cannot delete the programs from your machine as they are retained in a ROM chip , hard coded into the chip and are loaded each time you cut your machine on. The only thing you can do is delete the icons on the desktop, which are sent to the recycle bin.
To retore the machine to factory settings, there is a small hole just about an inch down from the data plate on the back. Using a pencil point or a straightened paper clip, insert the bject into the hole and hold for about 5 seconds. Your deleted icons are not replaced.
A second method to restore your icon is to click on my computer right click on the recorder, select copy, dismiss my computer, find a blank spot on your desktop and right click on that spot, select paste, and a dos type icon appears as your recorder button. When you cut the machine of and back on the Dos type icon is replaced with a CE type icon
To restore all icons:
You can: If you can click on start, click on run, type desk top into the open space and ok it. your icons should be shown. you will have to copy and paste each one back to your desk top, or select edit and then select select all, then click on file, select send to, and select desk top as short cut. Reply
Dec 12, 2010 | Sylvania G-Netbook
Hello, I have a 22'' ASUS VK222H Monitor hook up to my computer. I had Vista Business and everything was good. I installed Windows 7 today. Now I see only about 3/4 (three fourth) of the screen is occupied...
Jan 30, 2010 | ASUS VK222H Monitor
Hp 2480 desk jet printer prints photos with a large white border at the bottom how do i fix this? - thanks - Andy
Cleaning cartridges
# Open HP Solution Center:
* Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
* Windows Vista: Click the Windows icon , click All Programs , click HP , and then click HP Solution Center .
HP Solution Center opens in a new window.
# Click Settings
#In the Print Settings area, click Printer Toolbox . The printer Toolbox opens.
#On the Device Services tab, click Clean the Print Cartridge(s) ( ).
#Click Clean to begin the process.
Can check by cleaning the Roller inside - Problem usually come because of the dust on the roller
Happy new year
Jan 03, 2010 | HP Office Equipment & Supplies
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
RIGTH CLICK THEN DISCKTOP THEN PROPERTIES,DESPLAY AD SETTING, CHANGE INTO 1024 BY 768 PEXILS.... TO FIT THE SCREEN RESOLUTION 32BIT ONLY
Jun 04, 2009 | Dell Inspiron 8200 Notebook
Computers & Internet Logo
73 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
