Electrical Supplies Logo
Question about Electrical Supplies
Swingline model 67 repair
I have a 11hp briggs & stratton generator model 252412 type0238-02 code 82022311 that has been sitting for a long time and it wont produce power I have been told it needs exciting can somebody tell me how
tebrown507
    Sergeant:
  • 415 Answers
Look on YouTube for videos on how to flash the field on a generator.
Posted on Sep 08, 2014
5 Related Answers
Anonymous
  • 169 Answers
SOURCE: Generator doesn't excite with small power tools.
Somewhere on the Generator is an Idle Control switch, turning this to the off position will stop the generator idling down in the first place. You'll need to do this to use tools that don't draw enough current to trip the idle control system into revving the engine.
It may say just how much current you have to draw in the manual (hint, hint).
Posted on Nov 29, 2008
Anonymous
  • 131 Answers
SOURCE: looking for diagram and manual for a 11HP briggs
http://www.briggsandstratton.com/maint_repair/manual_and_more/index.aspx
gl
G
Posted on Jun 24, 2009
Anonymous
  • 108 Answers
SOURCE: can not excite generator
most generators you can polarize the brushs this is done by using a 12v. battery and a set of jumper cables hook to the battery and touch the brushs with the other ends it doesn't matter whicht side, but before you do all that check the connections at the brushs and see if they are loose or not making a good contact, i do hope that i was able to help you, thank you.
Posted on Jan 08, 2010
Anonymous
SOURCE: briggs and stratton 11hp generator giving spark
how long has it been since it last ran? I had a similar problem with mine so I put clean fuel in it with a mixture of sea foam gas treatment. Used a shot of starting fluid to get started and let it run for an hour or so. Just started it again yesterday with no problems. The fuel in carburetor is most likely old and needs to be gotten out of. If you try this and get it started let it run in half choke position for a few minutes so old fuel will get out of caburetor. Good Luck
Posted on Feb 20, 2010
Anonymous
SOURCE: No power output from Briggs & Stratton ProMax 7500E generator
check the AVR.
Posted on Jun 14, 2010
Mowmaster 11hp sit on 36 sit on mower fails to drive on uphill gradiants sometimes . any ia deas?
check the drive belt for having oil on it and missing pieces and enough tension
How to seperate generator head from back of engine
Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!
5helpful
2answers
The generator starts ok but no electric been produced and no light on
my generator has lost it's field. How do I recharge it? there are 5 wire from the generator: red, black, yellow/green and two green. I assume that the two green wires are the field. as the red black and yellow.green goes to the output plug.
Briggs and stratton 11hp generator giving spark and new fuel pull start but just wont kick over any tips
1helpful
Need over size exhaust seat for 11hp model253417
Go to the Briggs & Stratton web site. Put in the model, type, and code numbers off your engine. You can download the IPL (illustrated parts list), which will give you the part number of the seat - IF available. You can then order the part, but it will be a machine shop job to fit it.
Top Electrical Supplies Experts
Steve
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
