Question about LaCie Computers & Internet
How to take apart and disassemble lacie poulton external hard drive case
3 Related Answers
Anonymous
  • 23 Answers
SOURCE: lacie 250 gb (neil poulton) external hard drive
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Posted on Jul 18, 2009
Anonymous
SOURCE: Disassembling Lacie Hard Disk 500GB By Neil Poulton
this link shows you how to do it:
http://larrysthings.net/2009/05/31/opening-case-on-a-lacie-hard-disk-neil-poulton-designed-box/
Posted on Feb 06, 2010
Anonymous
SOURCE: Lacie 1T Poulton design external hard drive is clicking
Before you resort to freezers and desperation, know that the external power supplies for these things are a. crucial and b. delicate. If the output voltage is down for any reason, it can produce the same clicking symptoms. I would get to a repair shop, and ask them to test the drive with a 'known good' power supply. I did so this very morning with a LaCie drive: no more clicking, happily mounting drive...and power supply replaced under warranty. Good luck
Posted on Feb 19, 2010
How do I fix a broken port on my LaCie 320 gb hard drive that won't connect to the info?
It's really quite a simple fix... Simply disassemble the drive casing, and remove the hard drive itself, it's actually quite simple. Then install the hard drive into another, replacement external case - they are available at electronics retailers, computer stores, The best deals are found online at locations such as Amazon, eBay, or buy.com.
Jun 01, 2014 | LaCie (301151U) 320 GB USB Hard Drive
I need to install lacie stup assistant.or download
LaCie Setup assistant is made to make it easier for the customer.
If you do not have it, you can format your drive using your MAC or PC and you can download manual and utilities from the LaCie website, which are the only things the assistant really does.
Regards,
Jan 10, 2011 | LaCie Hard Disk design by Neil Poulton...
Hi. I have a LaCie Hard Drive designed by Poulton with N2870 on it. I've misplaced the external power cord adaptor, and need to know what kind to get. The guys at Radio Shack said they need to know: ...
I have the same one. The power supply I have says input 100-240V output is 24W 12V 2A.
I'm replacing the power supply but my big problem is not knowing the polarity of the tip There is no sticker on the hard drive itself or on the power supply (that I suspect is fried). Can anyone help?
Lisa
Dec 13, 2010 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Harddisk woun't mount
The hard disk inside it has probably died. Take it out of the case and put it in the pc directly - if even now it's not responsive then it's surely dead - junk it. if now you can see it then the electronics if the case are dead - junk it and buy a new external case.
Jul 19, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My 500G Lacie external drive is no longer detected by windows. Sometimes it will say the USB port or device is mulfuction. Sometimes it does not detect it at all.
Does this happen in several computers? If it does, then the interface is probably damaged, in which case you could (at your own risk) disassemble the drive and install the hard drive inside a desktop computer to access your data., since theres a standard SATA hard drive inside.
Mar 21, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Feb 08, 2010 | Computers & Internet
My LaCie is not recognized by my computer, makes a clicking noise when it tries to start up. I've used this external hard drive for several years with no problems.
It has most probably just reached its "end of life". Several years for a hard drive reading and writing is a good track record.
You can probably take the casing apart and replace the hard drive. Just make sure that this is an USB 2.0 interface before spending the money.
Oct 20, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Lost my data from my imac drive trying to backup to my Lacie.
yes U can recover it... plz download the registered version from the torrent site of software know as DATA DOCTOR RECOVERY .. this software will help you getting back you Data if you did not formated the Hard drive.. thank u for asking Question..
Jun 23, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
May 05, 2009 | Computers & Internet
Computers & Internet Logo
296 people viewed this question
Top LaCie Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
