Question about VeriFone VX510
Verifone vx510 wont print also error no connectionPAYM
5 Related Answers
hellonnnewma
DT
  • 26 Answers
SOURCE: How can I solve the problem **tamper** in Verifone Vx510?
Verifone has a built in safe-guard against tampering. There are certain things that can cause the new Vx Series of terminals to display this error - from someone actually tampering with the terminal, to a physical drop or jarring of the terminal.
I hate to be the bearer of bad news, but the ONLY way for a terminal to be unlocked when displaying "Tamper" is to send it into an authorized service center. I have many of these devices in the field for customers and have dealt with this issue a few times - unfortunately, that's the only way Verifone set it up for this error to be resolved.
Sorry for the bad news, but hope it helped!
Posted on Sep 05, 2009
Testimonial: "I suspected that. Anyway I appreciate your attention and your cooperation."
Anonymous
  • 3 Answers
SOURCE: Instruction manual for Verifone Vx510?
http://www.verifone.com/PDF/guides/23216_Omni_5xxx_vx5xx_vx6xx_Installation_Guide.pdf
Posted on Feb 18, 2010
Anonymous
SOURCE: i have verifone vx510
Well right now the credit card terminal has no programming software. What you need to do is get in contact with your merchant services number, most have a sticker on the terminal, or there is a 1800 number depending who processes your transactions. You will have to them put in a request to build a new file with your merchant number that is assigned to your business. After that file build is done you will need to download it on a dedicated analog phone line. The 1800 number can instruct you how to complete this process.
Posted on Feb 27, 2010
Anonymous
SOURCE: can verifone vx510 (Omni 3730 work on a digital
It's really hit or miss. Some days they will work, some days they will not. You will only really run into a problem when your doing downloads or batching the terminal out. You will sometimes have problems running cards, but make sure you hit the reports key if you get a disconnect to make sure the transaction didn't go through already before running the card again.
Posted on Oct 01, 2010
Mario. S.
  • 113 Answers
SOURCE: How can we resolve bad
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
Posted on Jan 13, 2012
2answers
Why is screen indicating download is needed?
PDF]Verifone VX510 User Guide - Moneris Solutions
www.monerisusa.com/support/~/media/Files/.../Vx510_qrg.ashx
VeriFone Vx510 with SoftPay. Quick Reference ... their PIN, and encourage them to protect their PIN. ERROR ... the terminal screen. ... PINpad display is blank: See "PIN Pad Error" ... the ALPHA key (repeatedly if necessary until the desired.
[PDF]Vx 520 - User Guide - Verifone Support Portal
Wont come on
Hi Dewayne,
There could be several different reasons for your Verifone not to come on? I would recommend that you Download & Save to your Computer and Print Out the FREE Pdf Manual.
I have (2) different links for you...
www.verifone.com/.../guides/23216_Omni_5xxx_vx5xx_vx6xx_
www.ebrowse.com/verifone-vx510-user-manual-pdf-d15147275
If you still can't reslove your problem, please feel free to reply back to me and I'll be happy to assist you!
Have a Great Day!
Martie
5helpful
4answers
How can we resolve bad rtc chip error in verifone vx510?
Can I print a cash payment receipt on the Vx510?
I SEARCHED THE VIERIFONE TECHNICAL SUPPORT SITE AND...YES YOU CAN PRINT CASH RECEIPTS. USES STANDARD ROLL PAPER 58mm (2.25 in) X 25M (82 FT) SINGLE PLY.
PRINTS 18 LINES PER SECOND 32 OR 42 COLUMNS.
IT HAS AN INTREGRATED THERMAL WITH GRAPHICS CAPABILITIES.
HOPE THIS ANSWERS YOUR QUESTION?
KIND REGARDS!
MARTIE
1helpful
Our Verifone VX510 printed our detail report at closing last night, but the settlement failed multiple times. Now we are unable to use the machine to process a debit or credit card transaction because it...
This problem could have multiple causes. It sounds like you are receiving a settlement error, which are specific to each merchant services provider. You will have to call the merchant services provider so that they can look up the error message on their end and tell you what is causing the error. For example, the error message that you would receive if you use First Data would be different than the message you would get if you used Bank of America. Your terminal will not let you run any more cards until you resolve the settlement error. This is to prevent you from continuing to run cards in a corrupted batch, or a duplicate batch.
6helpful
2answers
I have two verifone vx510 cc machines. 1st) Need
My verifone vx510 display ***** security alarm ******* BAD RTC CHIP PLEASE REBOOT
I am using verifone vx510 ,When I insert a card it is show Connection failed. What should I you?
2answers
TAMPER P.O.S VX 510, COMO RESOLVER
which types of Vx510 Tamper error showing on screen?and how many Vx terminals are in problems?
[email protected]
4helpful
9answers
Abri mi terminal Verifon vx510 para darle mantenimiento pero cuando la volvi a cerrar solo parpadea la pantalla, creo que se activo el tamper como lo desbloqueo o restauro, algun switch activa esto
buenas tardes lo que debes de checar son unas gomas que tiene adentro son las que activan el parpadeo o si necesitas ayuda mandame tu correo el mi es [email protected]
VeriFone VX510 Logo
Top VeriFone Retail Supplies Experts
Electroboy
Electroboy
ADMIN Canada
ADMIN Canada
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
