Question about Lite On LVC-9016G DVD Recorder/VCR
I have been recording on 1-8X DVD+R. Purchased new disks 16X DVD+R and when inserting disk, reading then request record function, am told to change disk.
SOURCE: lite on dvd recorder lvw-5045
the point is what was it doing before it start to do what it is doing now.kindly explain then i will be able to help you
Posted on Feb 25, 2007
SOURCE: Won't read DVDs
Taking off the case and using compressed air worked for me! :-)
Posted on Feb 04, 2008
SOURCE: Lite On LVW 1107 HC1 DVD Recorder
Concerning a Liteon LVW-1107.
I have had this same problem many times up until I decided that my machine tends to prefer +R or +RW disks. I have had no problems with +R or +RW disks.
( If I record something on a +RW disk and decide I want to copy it to -Rs I will copy the files to the hard drive and then reburn to
-Rs using Nero.)
Once you have had the disk in the machine and it will not play for whatever reason you might just as well throw it away and get a new disk and start over.
You may need to pull the power cord and let the machine reset on occasion also.
Realize I am telling you what works for me.
It may or may not work for you.
I hope it does.
Posted on Feb 13, 2008
SOURCE: lite on lvc 9016g will not prepare dvds or record
I had a problem with a Lite-On that had been working fine then stopped reading any disc--sometimes it would go through the motions of recording if a disc was in and a timed recording was due to start. After recording it would not read the disc. I tried a DVD/CD lens cleaner but it didn't appear to even spin up. A google search led me to find the a dirty laser would cause this. I removed the cover and with a clean lint free cloth I used rubbing alcohol to clean it and it has worked fine since. While I had the cover off I took the unit to my garage and used an air compressor to blow all the dust out of the unit and cleaned the laser again just in case. That was about 6 weeks ago and it works fine. My unit has a cooling fan that I think contributed to the dust problem.
Posted on May 19, 2008
SOURCE: liteon 5045 dvd recorder does
THE OPTICAL PICKUP (LASER() NEEDS CLEANING OR REPLACING.
SUPER8
Posted on Dec 01, 2008
