Question about Canon PIXMA iP5000 InkJet Photo Printer
<!-- from fixya rte -->Alternate green orange flashing - Canon PIXMA iP5000 InkJet Photo Printer
5 Related Answers
goodgold
Sergey Artuganov
  • 389 Answers
SOURCE: power lamp flashes green and alarm lamp flashes
simultaneous or alternative flashing all light bulb on panels of governing the jet printer and full blocking all function printer. In these cases counter possible reset by means of striking determined combinations of the buttons or software tools. Some models printer such, as Epson Stylus Solor 480, 580, C20, C40, C41, C42 and many new models (Epson R240, R800, R1800, RX500, RX520, RX600, RX700, CX3500, CX3700, CX4700) are thrown only by software tools, in change from the other models.I have some program goodgoldinbox.ru my email please write me a model of printer and wil be reset
Posted on Sep 12, 2009
alex cataldo
  • 70 Answers
SOURCE: Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Posted on Oct 25, 2009
Anonymous
  • 787 Answers
SOURCE: Power Lamp Flashes Green and Alarm Lamp Flashes 7 TIMES
Count how many times blinks orange lamp and check this error in this forum.
Posted on Nov 05, 2009
Anonymous
  • 15 Answers
SOURCE: Power light (or Alarm and Power lights)
Try resetting the printer by unplugging the printer from the power source for 5 mins. and they make sure ink is full and paper is loaded and not jammed. If not resolved carefully remove all ink cart from machine without touching and ink cart metal contacts, reseat the ink cart and reset and the printer.
Posted on Feb 21, 2010
Anonymous
  • 37 Answers
SOURCE: canon IP4300 flashes orange and green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Nov 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
Orange and green lights flashing alternately
If the light is orange and green flashing alternately, there might be a service error that requires your printer to be repaired. There might be an error message display.
check your ink cartridge if it is properly installed.
or
If it still doesn't work visit your local dealer or a computer repair shop for assistance.
Apr 06, 2009 | Canon PIXMA iP90v Printer
Canon Pixma MP600R shows Error Code6000. Green & Orange Lights flash alternately and cannot use any of the printer /scanner functions. Help!!
Each colour flashes alternately on a continuous basis for as long as I leave the prnter on - i.e. green , orange, green , orange, green , orange,............
Thanks,
Mar 28, 2008 | Computers & Internet
Canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Feb 17, 2008 | Canon i250 InkJet Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
83 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
