Question about Canon PIXMA iP5000 InkJet Photo Printer
How do I clear error code?
Error 5100
2 Related Answers
Anonymous
SOURCE: error code 5100 - can't clear it
Lift up below the display screen.The printer top will raise up and a arm will lock into place.Make sure the ink cartriages are firmly in place,snaped into position,sitting flat.Lift arm out of the way and close the lid.Worked for me ,good luck.
Posted on Oct 08, 2008
Saba Asim
  • 173 Answers
SOURCE: i80 printer error code 5100 appears
http://www.ehow.com/how_6527399_fix-error-5100-canon-i860.html
plz click this link
and find the instruction how to remove this error
Posted on Dec 23, 2011
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Www canontechsupport com
Usually an error 5100 code is saying that the ink carriage has problems. Usually something currently is or recently hammed the cartridge carriage. With the machine turned off and the power cord unplugged, open the machine and inspect the inside do you see any stray pieces of paper along the paper's usually route?
There is a way to reset the machine to clear out the error. I would need to know the exact model of your Canon.
for more help visit CBR Tech Solutions
Apr 02, 2014 | Canon Office Equipment & Supplies
Hi, I had a paper jam and all I'm getting on screen is ( error code 5100 ). I have missplaced my manual, the machine is a pixma460 all in one. Hope you can help, thanks,
Error code 5100 means that the movement of the fine cartidge holder is blocked. To resolve this, clear the paper jam or any foreign object that is preventing the fine cartridge holder from moving, cancel printing from your computer and then turn OFF the machine and turn it back ON again
Apr 08, 2010 | Office Equipment & Supplies
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Printer error code 5100 I had a business card paper jam in my Canon MX700. I removed the back panel & was able to clear the obstruction, but I keep getting the Error code: 5100. I've tried turning the...
Hi You can Try
Same old Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Feb 16, 2009 | Canon MX700 Office All-In-One InkJet...
Canon Pixma iP4500 error 5100
Hi You can Try
Another old posting
Error Code 5100
Solution 1:
Solution 2:
Oct 17, 2008 | Canon Pixma iP4500 InkJet Printer
Error code 5100 - can't clear it
Oct 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA iP5000 InkJet Photo Printer Logo
64 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
