Question about Epson WorkForce WF-7620 Wireless Color All-in-One Inkjet Printer
Why is my WF 7620 using excessive black ink?
I can only get 50 letters out of one ink cartridge
drivealot
    Habit-Forming:
  • 61 Answers
Check the print settings. Do you have it set to Photo, Best or economy? Usually this is done in the Epson application and/or at the print window. Higher settings will use more ink.
Posted on Sep 07, 2014
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: Epsom Rx620 states use originals for ink cartridges
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
Posted on Oct 29, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Can I use 4 black ink cartridges at the same time
No, the printer uses all cartridges for each print.
Posted on Jan 31, 2009
graemevm
Graeme van Malsen
  • 519 Answers
SOURCE: Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Posted on May 07, 2009
Why won't my Epson WF-7620 print on thick paper when fed from the rear slot
Are you setting the printer to A3 when you hit print? When you select print you will get a on screen box where you can change options and then confirm by clicking print. Most printers are set to default legal size.
Aug 07, 2016 | Epson WorkForce WF-7620 Wireless Color...
Epson WF-7620 will not print black.
I had a similar problem on my 3640 and had to run the clean cycle about 20 or so times. If you feel you are capable, you can also remove the print head and do a manual clean. YouTube has a few videos on how to do it. I have done this to one of my printers with very good success.
Apr 26, 2016 | Epson WorkForce WF-7620 Wireless Color...
The ink cartridge cover is not latched. what do i do
I had the same error on my WF-3620 with CISS and the solution is simple: my ink cartridge cover is removed and the only way how printer can determine that the ink cartridge cover is not latched is when something prevents ink cartridge carriage from moving to the right edge. In my case somewhy ink cartridge carriage got stuck and I just pushed it slightly with my hand and the error got solved. Note that you have to push ink cartridge carriage when it tries to move immediately after you press cover open sensor.
Feb 09, 2016 | Epson WorkForce WF-7620 Wireless Color...
Why is there a black vertical line in scans and copies?
Are you using a toner or a cartridge? There must be some ink leaked. If it is a toner, take it out and gently clean the excess ink and try.
Nov 03, 2015 | Epson WorkForce WF-7610 Wireless Color...
Why will my Epson wf7620 not print black ink after replacing the cartridge?
Hi. I don't know if your printer is new or old or if this was the first time you replaced the cartridge or this has occurred after several changes. Most if not all printers will have this occur after replacing a cartridge if the ink had been depleted for some time and allowed to dry up in the jets. Sometimes all it takes is a day for this to happen. I have found that I must go through several cleaning cycles to clear the clogged jet(s). So, try doing a few cleaning cycles and see if that solves the problem. Another cause for a printer not printing after replacing a cartridge is surprisingly a FAULTY or remanufactured cartridge. There should be a program on your computer that displays the cartridge condition, cleaning procedure and ink levels. Give that a look over.
Feb 20, 2015 | Epson WorkForce WF-7620 Wireless Color...
Reset Epson WF-7610
I've seen a program reset function which is downloadable from the internet. You will have to google it. I think it's only available on a windows operating system.
Sep 07, 2014 | Epson WorkForce WF-7620 Wireless Color...
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Apr 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Epson WorkForce WF-7620 Wireless Color All-in-One Inkjet Printer Logo
126 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
