Televison & Video Logo
A
Anonymous Posted on Sep 04, 2014
Tv will not turn over from bbc to other stations
Chris Frost
Level 3:
  • Master 985 Answers
  • Posted on Sep 07, 2014
Chris Frost
Master
Level 3:
Answers
985
Questions
0
Helped
218210
Points
3239
Are the other stations tuned in. If the TV is stuck only on the BBC stations then it suggests it has only picked up the most powerful channel group, which is the BBC mux.
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Feb 13, 2010
SOURCE: unable to get bbc 1, 2 or news since switchoff on
reset to factory defaults and start again, fixed my problems
Screen freezes BBC Channels only. Unfreeze by switching off TV. Handset and TVs buttons fail to work. Minutes laterscreen freezes again. No problem with non BBC channels
turning tv off and on wont make it better
you on roof antenna or a cable tv
if antenna only
you may be in weak signal area
or a new construction site or buildings deflecting the signal
antenna problem or needs upgrade
go back to TV set up and re-tune tv to bbc if possible
if it freezes then you know its an interrupted signal
How do I Get all radio stations on my remote .
That depends on how your TV is set up for radio reception.
Some TVs have a dedicated FM/AM radio tuner. This requires signals from both forms of radio antenna.
More commonly now though, digital TV includes a wide range of radio stations broadcast as part of the TV range. In the UK, the radio stations are grouped in the 700+ channel range. e.g. 701 is BBC Radio 1.
Bbc television
You're picking up the big transmitter in Norfolk that transmits for a different TV region.
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh. Then remember to set your region so the TV knows how to sort just for your local stations.
WHY CAN'T I "LISTEN AGAIN" TO LOCAL BBC RADIO,VIA BBC iPLAYER?
Can you provide a link to the app? I looked and didn't find anything official for Android.
Mark
Motorola Support
Why can I not make the BBC Radio app work on my iphone 4. It did work well for some months but now even when I have full strength signal on 3g via ee it simply hunts and will not start. Thanks Roger
(Just to be clear, this is the BBC Radio app, right? If your problem is the BBC News app, I may have a different suggestion.)
Do you have the latest version of the app? It appears that BBC Radio just updated the app a week ago on 31July2014 (Version 1.5.3), but it requires iOS 6.0 or later and is optimized for iPhone 5. I see you have an iPhone 4.
Do you have iOS 6 on your phone? And do you have the latest version of the app?
iOS 6 is supposedly completely compatible with iPhone 4s, and it is also supposedly compatible with iPhone 4 except iOS 6 on:
  • iPhone 4, does not support:
    • Siri
    • Maps flyover
    • Turn-by-turn navigation
    • FaceTime on 3G
    • Hearing aid support
So, it seems to me that this app should still work on your phone, unless you don't have the proper operating system or you haven't upgraded to the new version.
(the info below is copied and pasted for your viewing)
What's New in Version 1.5.3 FIXED - problem with automatically finding your local station
Please note that you can also choose any local station from the option beneath the dial after turning it to 'Find Local Radio'. You can even add up to 3 selected local stations to the dial using the Edit function.
Compatibility: Requires iOS 6.0 or later. Compatible with iPhone, iPad, and iPod touch. This app is optimized for iPhone 5.
1helpful
How do i watch bbc i on my t/v
Look at your station line up. Comcast provides a BBC station for its viewers. If you can't find it, call your provider and ask them if they carry the BBC channel and what the number is.
2helpful
I am using a Denon internet radio on LAN (pirelli modem), works fine, but I cannot receive BBC. BBC on the PC works fine. Could that be a router problem? Any ports or adjustments I have to consider? If so,...
I have the same problems with my Pirelli modem in Austria (A1) trying to play BBC radio stations. I connected my Denon CEOL RCD-N7 to a different network (SilverServer in Austria) and it played the BBC radio stations swimmingly (not sure what modem was used btw)... I have another internet radio at home (Reciva based) and surprisingly, that one plays the BBC stations fine using the WMA streams.
I do have a workaround now for the Denon system: I have added the following URLs (AAC streams) to "My Added Stations" on RadioDenon.com and they work like a charm:
http://www.bbc.co.uk/radio/listen/live/r1_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r2_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r3_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4x_aaclca.pls
Any suggestions as to what the issue might be with the Pirelli modem are welcome!
-- Hope this helps.
Cannot get the bbc channels
Did you have it before? If you are going through a cable box switching to a digital channel and tv could have it on another station. Call your provider.
2answers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
