Question about Technics SL-1200MK2 Turntable
Technics 1210 pop up light?
I recently installed two pop lights and two tone arms on a set of technics 1210s. Use technics replacement parts. Everything works fine except for one of the pop lights. when i press the start/stop button the pop up light goes faint. Also when i slow down or speed up the platter with my hand it also goes faint. i have tried changing the wires coming from the bulb around. but there is no change. I have also checked my soldering to make sure their are no problems with any of the connections.
Posted by LewiK on
Eko-Tiger
Maybe you should try putting a smaller (in Watts) lamp in the pop light...
Posted on Nov 13, 2007
I have recently removed the tone arm assembly and replaced the tonearm rest on my 1210's and now the tonearm is stiff horizontally so it stays in the same place and won't move across with the groove....
Check the arm wires have not got caught around the anti skate mechanism.
Did you adjust the screw / lock nut on top of the arm?. It's not supposed to be moved but if you did it might be to tight.
May 19, 2010 | Technics SL-1210 Turntable
How do i replace the arm lock on my 1210?
Hi, there is a screw that comes up from underneath the tone arm clip that needs to be undone o remove the tone am clip. [email protected]
Nov 28, 2009 | Technics SL-1210 Turntable
Tone arm pulls back on my technics 1210s
your needles gone.or you've moved the tip by touching it.
try & twist the tip back straight.
A LITTLE TIP FOR YOU ....u should never wipe or
touch the tip of a needle with your fingers coz the greese off your skin ***** them.blow it or use a little fine brush.
Aug 04, 2009 | Technics SL-1210 Turntable
How to replace target bulb in 1210?
Instructions on replacing your pop-up bulb can be found here: <a href="http://1200s.com/Service/Tech/Settings/pop-upbulb.php">REPLACE TECHNICS POP UP LIGHT / BULB</a> - OPTiC The ORIGINAL 1200 TECHNICIAN. www.1200s.com www.djproaudio.com www.djprolab.com Technics DJ Repair Videos Technics DJ Repair Technics DJ Parts DJ Parts DJ Equipment Sales Audio Video Accessories
Jun 03, 2009 | Technics SL-1200MK2 Turntable
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Apr 17, 2009 | Technics SL-1210 Turntable
Lamp replacement fears
No flying screws on the lamp (on this model anyway) you should have no problems!
Feb 13, 2009 | Technics SL-1210 Turntable
Tone arm replacement
Any TV repair shop will be able to perform that repair for you as well as get any parts necessary. Steve Medley
Feb 07, 2009 | Technics SL-1210MK5 Turntable
No Power to 1210s
Problem is not the fuses, but the power supply / power transformer has blown. This is why you should always wrap exposed wiring with electrical tape or heatshrink tubing.
The power supply can be purchased HERE, but this is not an easy replacement. And if you blew it by not properly replacing the Pop-up light, than I DON'T suggest you try to replace the power supply on your own either. You could really cause even more damage, and possible harm to yourself and your property.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ PRO AUDIO Co.
Nov 22, 2008 | Technics SL-1210 Turntable
1210 mk 2 strangeness
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Dec 01, 2007 | Technics SL-1210 Turntable
Technics 1210 mk2 problem with pitch and lights
- TWEAK AV LAB
Nov 30, 2007 | Technics SL-1210 Turntable
Technics SL-1200MK2 Turntable Logo
752 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
