Question about Polder THM560N FridgeFreezer Thermometer Stainless Steel
Daewoo nofrost multi flow freezer
Freezerpartnotworking
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Sounds like a gas problem if its new under warranty get it replaced.If its old dont repair,replace it.
Posted on Jan 17, 2016
How do i reset my Liebherr Premium Freezer, the freezer is not cooling and making ice
It needs professional service. If it is out of warranty, you'll need to call a service tech for a visit.
Nov 26, 2014 | Liebherr SBSes 74S2 Premium NoFrost
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
Freezer icing up
Maybe too much in the freezer at one time,or low on freon.
Dec 29, 2013 | Bosch KDN 36X10 NoFrost
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Aug 15, 2011 | Daewoo ERF336MB Freezer
Fridge freezer leaking
there should be a drain pan under in unit. it could be missalinged or the drain tube may have a hole in it. mice are good about this
May 22, 2010 | Daewoo Refrigerators
Daewoo regrigerator - Multi flow -
Go here at the bottom you will find yhe manual you need the model # though.
http://www.e-daewoo.com/owners_manual.asp
Good Luck And Please Rate FixYa!
Dec 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Polder THM560N FridgeFreezer Thermometer Stainless Steel Logo
443 people viewed this question
Top Polder Refrigerators Experts
Marvin
Marvin
john h
Are you a Polder Refrigerator Expert? Answer questions, earn points and help others
